oxygen sensor?
I discovered that the plug for my O2 sensor is broken and the wire was just hanging loose in my engine bay.
Pics below - it appears that the sensor is meant to plug in just to the right of the fuel filter - where the stub is protruding in my picture.
Do I need to replace the whole sensor - or an I just put a new cap/connector on? I don't see one for sale on Pelican - in fact the cheapest Bosch sensor they sell doesn't appear to come with a connector.
Strangely the car was running pretty well with it not being attached - although my emissions were probably off. Is it critical to remedy?
1983 911SC
2005 911S
Old 03-27-2017, 04:09 PM
Welcome to the inevitable O2 connector crap out. Basically the plastic covering around the old connector become brittle and falls apart. Here's the bummer..........there is no OEM replacement. Here's the good news.....it can be fixed one of two ways. One way is even better than OEM, and the other isn't as pretty but also works.
The better than OEM way is to order a custom made replacement from Louie85 on this board. I just installed his manufactured part on my car and it fits and works beautifully (pic below). The other way is to simply cut the two wire ends to expose them and fit any male/female ends that you can pick up at the local auto parts store. Be aware that on the engine harness (male) side the wire is double insulated so you need to carefully strip back the insulation to isolate the inner wire for the connection. This will work, but you won't have a nice fitting that can be held in the bracket.
Old 03-27-2017, 04:35 PM
Goth's Avatar
I had the same problem last year. I could only find one guy who had some made by his neighbor a few years ago. Since I could not find any available; I started making them in my spare time.
FYI...You should be able to just pick out the crumbling pieces in the black female O2 connector side. Then install this wire harness side male connector and you're good to go.
Here is a link to my original post in the parts for sale section (more pics and reviews): Replacement O2 Connector for 3.2L
If you would like one of these replacement kits: Paypal $59 to doug_s@prodigy.net and I can send one out to you ASAP.
Thanks!
Doug
84 Carrera Coupe - Black (the Goth look)
The more I learn, the more I realize I don't know
Old 03-28-2017, 04:53 AM
Thanks 997at and Doug. Didn't hear back from Louie. Doug - just Paypal'ed you the money.
Looking forward to fixing this niggle.
1983 911SC
2005 911S
Old 03-28-2017, 06:51 AM
Goth's Avatar
Thanks NikosF...I will get this in the mail today. A USPS tracking number will be sent to your PayPal account.
Cheers!
Doug
Old 03-28-2017, 07:30 AM
Great - received in the mail today!
1983 911SC
2005 911S
Old 03-30-2017, 11:23 AM
Goth's Avatar
Boy that was fast....Glad you got it so soon.
Doug
Old 03-30-2017, 12:13 PM
grateful user
don gilbert's Avatar
Motor should be much smoother now at idle and part throttle. Gas mileage will go up considerably to.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do.
Old 03-30-2017, 01:48 PM
grateful user
Make sure your getting power to the 02 system relay under the seat, just unplug it and plug it in with key on, listen for the click,
and you should feel your freq. valve vibrating when the engine is running.
Old 03-30-2017, 01:50 PM
