-   -   How do I lock the tranmission for torquing the nuts under shift cover (http://forums.pelicanparts.com/porsche-911-technical-forum/807660-how-do-i-lock-tranmission-torquing-nuts-under-shift-cover.html)
kodioneill 04-22-2014 12:47 PM
I need to finish rebuilding a 915 with the final nut torque how do I lock the trans without the mainshaft spline tool?
And finally, I had to remove the mainshaft nut after staking (installed bearing backwards) can I reuse it with red loctite? There was some metal left for a small dimple to stake down but not much.
Thanks guys
kodioneill 04-22-2014 02:02 PM
Alright, I think the torquing problem is set I'll weld a steel bar to a old clutch disc and drill a hole in it to fasten it to the bell housing.
Still need input on the main shaft nut though.
Thanks as always.
MikeD 04-22-2014 04:33 PM
I put it in 2 and 5. I would get a new nut.
