Electrical plug what is it
81 targa decided to replace my oxy sensor today and check on some fuse wiring condition
Found this 3 wire plug not connected to anything Brown wire going to ground There's also a red wire and green wire anyone know what it's for ? ![]()
Test port plug........
That's the test port or plug for the ECU for checking the OXS/FV operation.
Tony |
Oh ok what do you plug in there ?
A dwell meter. A dwell meter is used to measure the frequency valve(fv) duty cycle. The fv varies the air/fuel mixture based on input from the ecu and oxygen sensor when the car is warm.
Regards
1982 SC Targa Last edited by jasonfc99; 04-22-2014 at 06:46 PM.. |
El Duderino
It is a diagnostic port. You use the green/white wire to test the duty cycle of the ECU. Red is power. Brown is ground.
There are those who call me... Tim '83 911 SC 3.0 coupe (NA) You can't buy happiness, but you can buy car parts which is kind of the same thing. |
Ok thanks folks
