-   -   Problems after new alternator install (http://forums.pelicanparts.com/porsche-911-technical-forum/807988-problems-after-new-alternator-install.html)
ESC79 04-24-2014 12:55 PM
Hi Folks,
Need some guidance again. I just installed a new alternator in my 79sc. This involved switching from an external to internal regulator. I followed 101 pretty closely, made the changes per the Porsche tech bulletin, and believe I hooked everything back in the right place, etc. However, when I went to reconnect the battery I got arcing at the negative terminal, suggesting that something is drawing current and therefore not hooked up right (hopefully nothing got fried!).
Any ideas of places to check or if I pulled the alternator out again what should I look for?
Thanks as always!
kodioneill 04-24-2014 01:05 PM
Remove the alternator take some photos of your hook up post them here.
ESC79 04-25-2014 05:50 AM
Thanks kodioneill.
Here are two photos. Let me know if they look right.http://forums.pelicanparts.com/uploa...1398430182.jpg
http://forums.pelicanparts.com/uploa...1398430192.jpg
kodioneill 04-25-2014 06:08 AM
can you pull the rubber boots back and take another photo more directly on the back? I know it's tight in there.
ESC79 04-25-2014 06:27 AM
Let me know if these help!http://forums.pelicanparts.com/uploa...1398432423.jpg
http://forums.pelicanparts.com/uploa...1398432435.jpg
http://forums.pelicanparts.com/uploa...1398432450.jpg
http://forums.pelicanparts.com/uploa...1398432461.jpg
ESC79 04-25-2014 06:28 AM
If useful, here is the alt part number I ordered from Pelican: 911-603-120-04
clarkd 04-25-2014 07:10 AM
If you had the large ground wire located as shown, I would move it to another bolt away from the postive rectifier plate to prevent unintentional contact on install.
Flat6pac 04-25-2014 07:14 AM
All brown can be on alt. post as there is no need to ground housing.
The large brown is connected to centerline bolt on case?
Bruce
calimedeiros 04-25-2014 07:17 AM
When ever I hook up the negative lead don't you usually get a little spark as the conector touchs and battery. U may not have any issues
ESC79 04-25-2014 07:22 AM
Thanks - definitely could have been contact with the plate. So I'll move the large brown ground to the post with the other browns.
It was definitely more sparks than usual, which led me to think something wasn't quite right.
ESC79 04-25-2014 08:02 AM
One other quick question before I button it up: with everything connected should I see 'continuity' at the + and - battery cables (no battery connected of course) indicating that the current draw is still there?
E Sully 04-25-2014 08:20 AM
You will have power to the alternator, battery should be disconnected when working on it to prevent accidental short.
Here are the Tech Bulletins for the Internal Reg.
http://forums.pelicanparts.com/uploa...1398438955.jpg
http://forums.pelicanparts.com/uploa...1398438969.jpg
kodioneill 04-27-2014 06:14 AM
Is that blue wire pinched under the regulator?
