Problems after new alternator install
Hi Folks,
Need some guidance again. I just installed a new alternator in my 79sc. This involved switching from an external to internal regulator. I followed 101 pretty closely, made the changes per the Porsche tech bulletin, and believe I hooked everything back in the right place, etc. However, when I went to reconnect the battery I got arcing at the negative terminal, suggesting that something is drawing current and therefore not hooked up right (hopefully nothing got fried!).
Any ideas of places to check or if I pulled the alternator out again what should I look for?
Thanks as always!
Old 04-24-2014, 12:55 PM
kodioneill's Avatar
Remove the alternator take some photos of your hook up post them here.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 04-24-2014, 01:05 PM
Thanks kodioneill.
Here are two photos. Let me know if they look right.
Old 04-25-2014, 05:50 AM
kodioneill's Avatar
can you pull the rubber boots back and take another photo more directly on the back? I know it's tight in there.
1982 chiffon 911sc
Old 04-25-2014, 06:08 AM
Let me know if these help!
Old 04-25-2014, 06:27 AM
If useful, here is the alt part number I ordered from Pelican: 911-603-120-04
Old 04-25-2014, 06:28 AM
clarkd's Avatar
If you had the large ground wire located as shown, I would move it to another bolt away from the postive rectifier plate to prevent unintentional contact on install.
Old 04-25-2014, 07:10 AM
All brown can be on alt. post as there is no need to ground housing.
The large brown is connected to centerline bolt on case?
Bruce
Old 04-25-2014, 07:14 AM
When ever I hook up the negative lead don't you usually get a little spark as the conector touchs and battery. U may not have any issues
Old 04-25-2014, 07:17 AM
Thanks - definitely could have been contact with the plate. So I'll move the large brown ground to the post with the other browns.
It was definitely more sparks than usual, which led me to think something wasn't quite right.
Old 04-25-2014, 07:22 AM
One other quick question before I button it up: with everything connected should I see 'continuity' at the + and - battery cables (no battery connected of course) indicating that the current draw is still there?
Old 04-25-2014, 08:02 AM
E Sully's Avatar
You will have power to the alternator, battery should be disconnected when working on it to prevent accidental short.
Here are the Tech Bulletins for the Internal Reg.
Ed
1973.5 T
Old 04-25-2014, 08:20 AM
kodioneill's Avatar
Is that blue wire pinched under the regulator?
1982 chiffon 911sc
Old 04-27-2014, 06:14 AM
