FMyers's Avatar
Electrical Connector
Does anyone know the part no. or where to get one for the 'H' shaped connector for fog light wiring. I've tried to upload a photo but don't seem able to do it.
THANKS
Old 04-25-2014, 07:13 PM
Cooper911SC's Avatar
The part # is 999-652-142-40
"Push On Connector"
You can find it in the PET program under '87-'89 911
Main Group 9 (Electrical) Illustration 902-52
It appears as item 14. When you call to order it also looks like you will need to specify how many positions/connections.
They call out 1,2,3,5,&12
I have only ever seen the H shaped (2)?
They are basically an insulator that the female spade connector can also lock into. With a small thin screwdriver or the proper release tool you can bend the retaining tab flat and remove the electrical connector.
Cooper
Old 04-25-2014, 10:31 PM
ROW '78 911 Targa
timmy2's Avatar
These ones? Just need to cut 2 off and you get the H style.
Same as VW style $1 each at wolfsburgwestdotcom part #111937077 PSH WIRE CON 1-1
Just use 2 female spades instead of one male and one female.
When I was looking for these in the original configuration they came up as NLA...
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 04-25-2014, 11:04 PM
FMyers's Avatar
Thumbs up Electrical Connector
Thank guys for the information.
Old 04-26-2014, 07:59 AM
