-   -   Targa window power window with coupe windows (http://forums.pelicanparts.com/porsche-911-technical-forum/808250-targa-window-power-window-coupe-windows.html)
rebel 04-25-2014 08:45 PM
Anybody ever try to use targa window power drives with coupe windows in coupe frames? I bought a good set of doors for my coupe and I am trying to get the power drive for the targa to raise my coupe windows in the coupe frames. Unfortunately it is not raising the glass square to the frame? I have tried to adjust the drive lifter arms but no luck. Anyone tried this before? Or should I give up and go back to cracking the window?
rebel 04-26-2014 05:52 AM
Let me see if I can make this a little more clear. I have a coupe which had manual window winders and bought some targa doors. My plan was to have power windows but the targa hardware is not lifting the window square. When all the way up there is a gap so no driving in the rain? I was hoping someone had tried this before and might have some advice?
MrScott 04-26-2014 06:36 AM
I believe the upper and lower stops are adjustible. See this thread: http://forums.pelicanparts.com/porsche-911-technical-forum/400362-power-window-height-adjust.html
Plenty of other threads if this doesn't solve it.
javadog 04-26-2014 08:02 AM
Coupe regulators don't have the upper travel stop. You can remove that from the regulator.
JR
rebel 04-26-2014 10:18 AM
Javadog are you referring to the screw adjustment at the top of the door? I have that adjusted all the way up so the window does not hit it, still squirrely. Is there that much difference between the targa and coupe doors, looks pretty well the same to me?
rebel 04-26-2014 10:20 AM
MrScott thanks for the info I am headed out for some more adjustments.
javadog 04-26-2014 10:22 AM
I was talking about the regulators, not the doors.
JR
rebel 04-26-2014 02:45 PM
That did the trick on the passenger door. Still need a little more on the driver. I am moving the frame and regulator a little to see if I can get that last little bit. Thank you sir!
