El Duderino
tirwin's Avatar
For '81-83, relay #5 (from the front) is the power window relay. Part number is 911.615.109.01.
Try this.
- Pull fuse #21. It's the one closest to the back of the car. Do the windows still work? If so, someone has messed with the wiring.
-Put the fuse back in. Now put a piece of tape or mark the fuse that came out of #5 so you know which is which. Switch it with fuse #4. Try the power windows. Do they still work? They shouldn't.
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 04-30-2014, 04:36 AM
Hi, I have a 80 911 SC and my driver side window works but my passenger side don’t. I replaced window regulator and tested the window motor and it works. Any idea what might cause the problem? Does the 82 diagram the for the 80?
Thanks.
Old 05-19-2022, 08:31 PM
