-   -   Trailing Arm Bolts - washer required? (http://forums.pelicanparts.com/porsche-911-technical-forum/809018-trailing-arm-bolts-washer-required.html)
bodmin 05-01-2014 04:52 AM
Just been torqueing my trailing arm bolts, and was not sure I had assembled them properly.
Can anyone advise me whether a washer should be present under the head of the bolt? According to the PET there is only one under the nut, and I can't remember if one was present when I dismantled. I don't have any spare M14 washers lying around.
Car is 89 3.2. Obligatory pictures attached!
http://forums.pelicanparts.com/uploa...1398945064.jpg
http://forums.pelicanparts.com/uploa...1398945092.jpg
Shaun @ Tru6 05-01-2014 05:46 AM
PET says you are correct.
http://forums.pelicanparts.com/uploa...1398948373.jpg
bodmin 05-01-2014 01:44 PM
Thanks Shaun, just doesn't seem right without a washer!
Shaun @ Tru6 05-01-2014 02:06 PM
I know what you mean. It must be an engineering illusion that you would need to spread out the bolt head compression.
