| Registered Join Date: Jun 2009 Location: Edinburgh, Scotland
				Trailing Arm Bolts - washer required?
			Just been torqueing my trailing arm bolts, and was not sure I had assembled them properly. Can anyone advise me whether a washer should be present under the head of the bolt? According to the PET there is only one under the nut, and I can't remember if one was present when I dismantled. I don't have any spare M14 washers lying around. Car is 89 3.2. Obligatory pictures attached!    | ||
|  05-01-2014, 03:52 AM |
| Registered Join Date: Dec 2001 Location: Cambridge, MA
			PET says you are correct.
				__________________ Tru6 Restoration & Design | ||
|  05-01-2014, 04:46 AM |
			Thanks Shaun, just doesn't seem right without a washer!
|  05-01-2014, 12:44 PM |
			I know what you mean. It must be an engineering illusion that you would need to spread out the bolt head compression.
|  05-01-2014, 01:06 PM |
