Removing Catalytic Converter
Planning on swapping out my CAT for an M&K pre muffler tomorrow. Before I get started, does anybody have any tips/shortcuts on removing it?
For those who have installed a cat bypass, did you put that protective guard plate back on or leave it off?
1986 911 3.2 Cabriolet
"We all have a desire to create something that will show we were here. " Ferry Porsche
Old 05-03-2014, 09:12 PM
Porsche Owner
mark4ton's Avatar
have a torch handy to heat up the tough bolts and coat the bolts with anti-seize when you put it back together.
1987 Carrera - 2008 Cayenne Turbo
Old 05-03-2014, 09:50 PM
Cattler's Avatar
Porsche Crest
This took me a while due to rusted bolts. Here are a few tips:
  • a dremel tool with the fiberglass reinforced circular cutting blades is really helpful to remove the cat protective cover. Its not going back on, so no problem if you need to cut it or the support straps.
  • expect your cat bolts to be rusted over. Soaking in PB Blaster and using heat works some. In the end, I paid a shop to break them free and replace with my hardware.
  • Its possible to pay someone to do that, but you'll need to do the cat replacement yourself.
  • Buy a new oxygen sensor and install it in the M&K premuffler. Who knows when the one that's in there was last replaced? Why bother trying to break it free?
  • Save the old cat. You might need it someday and they're not worth much in resale anyway. I just left my old O2 sensor in it.
  • Expect a bad smell for ~200-300 miles while the M&K burns out all of its chemical protectants.
Enjoy,
Dave
1987 911 Carrera Cabriolet (sold)
2009 Prius (daily driver--keeps me sane)
2011 Mercedes GLK350 (wife's car)
2002 Volkswagen Beetle Turbo S (son's car--keeps wife sane)
Old 05-04-2014, 04:28 AM
The O2 sensor was the booger for me.... that old sucker wouldn't budge and I stripped it so had to pony up for a new one. The other nine or so bolts I went ahead and replaced so the "stuck" ones I just dremeled off.
'87 911 Carrera Coupe (go fast, small parts / small kids hauler)
'04 Toyota Land Cruiser (go slow, go anywhere, haul everything, the "AntiPrius")
Old 05-04-2014, 05:19 AM
Spiderman
Jesse16's Avatar
I did not put the heat shield back on, should be less hot anyway.
Midnight Blue 08 Cayman S, Fun/Track
Black 12 VW-GTI, work
Mexico Blue 87 Carrera, sold, sad, not enough garage space.
Old 05-04-2014, 05:51 AM
Burn the fire.
Brando's Avatar
Use new stainless hardware including washers & split washers. If you have to swap anything back (like, emissions testing) it will make your life much, much easier.
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 05-04-2014, 08:47 AM
