'73 911 T Targa
Tach doesn't work after Pertronix points install
I installed Pertronix points in my '73T and now my tach doesn't work. I finally found and used used the wiring diagram below, but only after several unsuccessful experiments. Is it possible I baked the tach, or is there possibly some other known idiosyncrasy with Pertronix and the CDI tach?
Old 05-03-2014, 07:14 PM
ROW '78 911 Targa
timmy2's Avatar
Are the Black wire from the CDI and the Purple/Black wire from 14 pin connector both connected to the Pertronix Black lead?
They should be.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 05-03-2014, 09:13 PM
The Pertronix, when connected as shown should not blow your Tach. If you go back to your original points setup does the tach start to work properly again?
Old 05-03-2014, 10:33 PM
304065's Avatar
What is the date on the back of your tach? Is the speed switch installed?
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 05-04-2014, 06:01 AM
