-   -   Tach doesn't work after Pertronix points install (http://forums.pelicanparts.com/porsche-911-technical-forum/809417-tach-doesnt-work-after-pertronix-points-install.html)
Quickstep192 05-03-2014 07:14 PM
I installed Pertronix points in my '73T and now my tach doesn't work. I finally found and used used the wiring diagram below, but only after several unsuccessful experiments. Is it possible I baked the tach, or is there possibly some other known idiosyncrasy with Pertronix and the CDI tach?
http://forums.pelicanparts.com/uploa...1399169279.jpg
timmy2 05-03-2014 09:13 PM
Are the Black wire from the CDI and the Purple/Black wire from 14 pin connector both connected to the Pertronix Black lead?
They should be.
Bob Ashlock 05-03-2014 10:33 PM
The Pertronix, when connected as shown should not blow your Tach. If you go back to your original points setup does the tach start to work properly again?
304065 05-04-2014 06:01 AM
What is the date on the back of your tach? Is the speed switch installed?
