'73 911 T Targa
Tach doesn't work after Pertronix points install
I installed Pertronix points in my '73T and now my tach doesn't work. I finally found and used used the wiring diagram below, but only after several unsuccessful experiments. Is it possible I baked the tach, or is there possibly some other known idiosyncrasy with Pertronix and the CDI tach?
ROW '78 911 Targa
Are the Black wire from the CDI and the Purple/Black wire from 14 pin connector both connected to the Pertronix Black lead?
They should be.
Dennis Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds. Last edited by timmy2; 05-03-2014 at 10:40 PM.. |
The Pertronix, when connected as shown should not blow your Tach. If you go back to your original points setup does the tach start to work properly again?
What is the date on the back of your tach? Is the speed switch installed?
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
