Ferrino's Avatar
Bench Testing Blower Motor
I have a Carrera heater blower motor (the one in the engine bay) which I would like to sell, but I've never run it as the previous owner did not have the relay installed. I'd like to test it before selling and was wondering if this can be done easily, please? Or do you need the relay to power it safely? Thanks.
Old 08-23-2014, 03:08 PM
Remove it so you can see the connector on the front
12volts on one pin, ground the other, should start spinning
Bruce
Old 08-23-2014, 03:23 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Make sure it is secure, it may roll off the bench when you power it up
'85 Carrera Targa
PCA/POC
Old 08-23-2014, 03:28 PM
Did exactly what Flat6pac suggested last week on an evaporator blower. Little alligator clips onto the battery and then onto the blades of the connector lead. Just touched the ground as the final connection and motor spun freely. Easy quick test. Not intended to test more that a few seconds.
Old 08-23-2014, 06:36 PM
wrxnofx's Avatar
A 9 volt battery works just fine to test it, too.
1987 911 Carrera coupe - Guards Red
2010 997.2 C4S 6-Speed
2005 Mini Cooper Convertible (R52) - Wife's car
1977 VW Bay Window Camper Bus
Old 08-23-2014, 09:25 PM
