What board for door panels?
I am in the process of constructing a flat door panel for my 1973 911 T and was wondering what board I should use? It looks like my old board(or should I say cardboard) is around 1/8" thick. Where can I buy a sheet of appropriate board? Also, what is this board called?
I already ordered new black leather from pelican to cover the new panels... Bill
William Armentrout 1973 911T 2.7 carerra rs specs |
Not Quite Banned
You can buy it at Home Depot. My father used to call it 'Masonite'.
Good luck.
Thomas Owen 1972 911T 1972 911S |
Administrator
And if you're fanatical about weight, the stuff to use is the corrugated plastic, like the stuff used in US Mail bins.
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
Original Fit Interiors uses/used Luan plywood. If you go with any material that absorbs moisture, I suggest applying a coat or two of polyurethane.
Sherwood Lee http://members.rennlist.org/911pcars |
Bill, you might also look into abs sheet mtl for the backing. Not to expensive, easy to cut and drill, takes glue well and is waterproof and not to heavy. Can be found at most plastic supply houses.
Jerry |
Bill,
I saw some plastic pegboard material at Lowe's a while back. Perhaps a bit thicker than the Masonite used by the factory ... but it won't absorb moisture! How well it would hold up to the 140°F++ interior temps in the summertime is anybody's guess.
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
I agree with Jack....the corregated plastic is the way to go.
It's stiff...light...plastic (sheds water)..and comes in white and black. I just completed my new door panels...with some naugahide and contact cement. They look very good....and I cut them out using big scissors. Bob
Bob Hutson |
Thanks guys. I'll keep you posted on my progress. I plan on buying a sheet of something this weekend.
I just received some Por 15, so I may give my trunk a coat this weekend before I tackle the door panels. Bill
Cheers Mark
'87 911 3.2ltr Cab. ROW (sold )'90 964 3.8 ltr C4 Coupe (P-Dealer built, track prep'd, sold ) )OMYG..I'm Porscheless |
