Adding conventional oil to Brad Penn?
I have always wondered if there is any harm in adding a quart of conventional oil, non-Brad Penn, but same weight as BP (20W50), if you typically always use Brad Penn?
So if one was on a long trip, didn't have BP to add, but wanted to add a little oil to the case, would you add conventional 20W50? Or is that a bad idea?
Curious....
Old 05-06-2014, 05:03 AM
Justin@Athens's Avatar
Send a message via AIM to Justin@Athens
No problems will occur. BP is a partial synthetic if my memory is correct, even if it wasn't there is no real cause for concern.
1990 964 C4 Coupe & 1991 964 C2 Coupe (current)
1989 911 Targa (sold)
1996 993 Cab. (sold)
1999 x2 Boxster (sold)
2006 Cayman S (my daily)
Old 05-06-2014, 05:39 AM
theiceman's Avatar
yes you are right .. BP is partial synthetic ... if i have to add on trips I throw in a quart of Valvoline 20W50 VR1 racing oil . no issues at all .
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 05-06-2014, 10:37 AM
Valvoline VR-1 20w 50 is so much better than that sludge forming brad pen BS it's ridiculous. ...you couldn't pay me to use that over rated bradd pitt swamp piss again in a turbo motor.
Been there done that and learned.. it can't take the heat of a turbo bearing housing and turns to carbon sludge turning the inside of the motor black with carbon sludge in less than 1000 miles.
Clean out the sludge in the cam towers, valve covers, and chain cases and then use Valvoline VR-1 non synthetic or full synthetic 20w 50 or best of all: Mobil One 15w 50 and everything stays clean..
Old 05-06-2014, 02:24 PM
Hydrocket's Avatar
If you want a full synthetic that has nearly identical additives as BP, Amsoil Z-Rod is the way to go....
1986 911 Targa We affirm that the world’s magnificence has been enriched by a new beauty: the beauty of speed. A racing car whose hood is adorned with great pipes, like serpents of explosive breath - a roaring car that seems to ride on grapeshot....
Old 05-06-2014, 02:31 PM
HarryD's Avatar
FWIW, in my non-turbo car, I have never had a sludge problem with BP.
If it was me, I would be using a 100% group 4 or 5 syn oil for Turbo applications. After all synthetic oils were originally made to address the coking problems in jet turbine engines.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 05-06-2014, 07:18 PM
Hydrocket's Avatar
Someone asked me about the numbers for the Z-Rod oil.
Z-Rod contains 1440PPM of Zinc and 1320PPM of Phosphorous.
Old 05-06-2014, 08:09 PM
