fuel leak
Greetings...At long last I found and bought my '87 930 and drove it home yesterday...on the way I filled up twice and it leaked fuel from the driver's side front fender on both fill ups...there's a hose that comes from the trunk area and terminates behind the head light...no smell of fuel in the trunk, only a steady drip in front of the tire...I don't think I over filled it, as no fuel ran out of the overflow tube behind the tire
eventually the leak stopped, but now the garage smells like fuel
please be gentle as I'm a noob and I'd appreciate any help
thanks!
Old 05-06-2014, 06:36 AM
E Sully's Avatar
I believe there should be an expansion tank in the fender as part of the evaporative emmissions system. The tank holds excess fuel when filling up and returns the fuel to the tank when filled, and also vents the fumes to the charcoal cannister in the engine compartment.
If the lines are old and cracked, replace them.
Ed
1973.5 T
Old 05-06-2014, 07:00 AM
Mine does that too... drips from the same spot. I found if I fill the tank full it's more likely to happen, particularly if you don't drive far from the station to your garage and park it. I just haven't gotten around to swapping out that vent line so I only add 10-12 gallons at a time... keeps the weight down too!
'87 911 Carrera Coupe (go fast, small parts / small kids hauler)
'04 Toyota Land Cruiser (go slow, go anywhere, haul everything, the "AntiPrius")
Old 05-06-2014, 09:23 AM
Thanks...I did take a better look under the fender and there is a tank in there...I will try putting so much fuel in next time
I appreciate the help!
Old 05-06-2014, 09:49 AM
theiceman's Avatar
Stop on the first click... you are filling your vapour tank ... That said however it shouldnt do that .. you need a new piece of hose and a couple of fuel line clamps..
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 05-06-2014, 10:33 AM
Thanks!
Old 05-06-2014, 11:02 AM
Agreed it's not normal to leak but it's only when the tank is completely full / overfilled.
On the plus side (not that any gas leak is really a "plus"), it's going to seep / drip straight to the ground and it's not near any heat / electrical sources. Mine's been this way for over a year now and if you watch how full you fill the tank you can still drive the car without much concern. If it's always damp with gas or a strong constant fuel smell you better fix sooner than later. There are a few other gas vent lines buried in the wheel well so plan on doing all of them while in there.
Old 05-06-2014, 12:22 PM
