Leaking Thermostat
Have been lurking for a while, but time for an opinion from the masses!
I've recently purchased a 1980 SC, and absolutely love it. Flew 1000km's to pick it up. Jumped in, and drove it back without a hitch. Fantastic! Well… almost… The external thermostat has a slow leak on the upper most fitting. It doesn't seem to be a torrent, but it gets fairly wet. I've gone through 1 liter of oil in about 2500km's. The question I have is… I've got an event coming up that would involve a 1000km road trip over 4 days. I'd love to do this in the SC, but am a bit nervous about the leak getting worse. Options are… Leave it, and just top it up as I go, and hope it doesn't get worse Try and tighten it, and hope it doesn't strip the threads. Tightening it, and/or loosening it is my biggest concern. Ideally, the oil that is leaking past will mean that the threads aren't seized, but if they are, and it strips, then it'll be a few weeks with the car off the road while I wait for parts. IE: no road trip. I have no problem sorting it out after the trip….. What are everyones thoughts on the chances of this leak getting worse? |
Eva
The leak will most likely get progressively worse...not by a lot.
I would pack some extra oil, accept the leak for the trip, and address upon return. Why? I have the exact same issue and am finally going to tackle this week-weekend. Changing the oil lines from engine/tank process ruined the threads on the t-stat. Despite my taking UBER care. I changed the lines 4/13, they began leaking 6/13...I drove the car another 2500miles since... In that time the leak developed from clean, to a seep, then to a run down the oil line, now after a drive it will emit 1 drip onto the ground below. Really annoying thing is the oil has gotten into the torsion tube and can be seen on the driver side tube end... After I install the new t-stat, some cleaning is in order.
'78 SC Targa ~Brynhild~ Insta: @911saucy "The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman- |
