911 sc 80 not start
Hi
I have a Porsche 911 sc of 80
The problem started last week I drove the vehicle on a highway the RPM stuck high around 2500 RPM
Also took the foot off the gas the RPM stuck high, only the power of the engine driving causing them to be lower. In neutral the RPM again rising,
After an hour I tried to turn on the car but the car would not start
Something no idea what to do or know
Thank you ...
Old 05-06-2014, 05:59 AM
You could have an air leak in the CIS from a cracked/broken hose or CIS component. Unmetered air in the system is similar to having the throttle open--it increases engine rpm and makes it difficult to start the car. Given the sudden onset of the problem, I'd suggest you check all vacuum lines and components for air leaks.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 05-06-2014, 07:13 AM
Cooper911SC's Avatar
Stuck/broken plastic mount for cruise control throttle cable?
Located on top of engine above where the metal throttle rod connects.
Plastic cable holder can break and stop throttle from completely closing.
Cooper
Old 05-06-2014, 07:56 AM
