-   -   Sick Of It! Time to update my SC Fusebox (http://forums.pelicanparts.com/porsche-911-technical-forum/810035-sick-time-update-my-sc-fusebox.html)
OsoMoore 05-07-2014 07:31 AM
For the third time this year my fuel pump fuse has loosened up and caused the engine to cut out or not start. Its annoying when it won't start and I have to pull out pliers and re-bend the fuse tab. Its dangerous when it cuts out while driving and I lose power.
Tonight I plan to stick in a quick hack with a modern fuse and a small splice for a weekend trip. Next week I want to begin a full box update. Here are the threads I'm planning to reference for info:
http://forums.pelicanparts.com/porsche-911-technical-forum/231634-front-trunk-restoration-porn-lots-pics.html?highlight=fuses
http://forums.pelicanparts.com/porsche-911-technical-forum/194614-fuse-panel-upgrade-ato-type.html
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/712237-ato-fuse-panel-last-call-before-christmas.html
http://forums.pelicanparts.com/porsche-911-technical-forum/386198-my-interpretation-fuse-panel-upgrade.html
Possible products
http://www.ceautoelectricsupply.com/fuseholders.html
http://store.chiefenterprises.com/Products/Multiple-Fuse-Relay-Holders/FP-ATO-S12
Useful images:
http://forums.pelicanparts.com/uploa...1349055170.jpg
http://forums.pelicanparts.com/uploa...1340306845.jpg
Anyone else have thoughts or ideas? I plan to keep this thread updated with my progress and links to what I purchase.
EDIT - More useful links:
http://forums.pelicanparts.com/porsche-911-technical-forum/594358-fuse-box-layout-help.html
Dave Colangelo 05-07-2014 08:32 AM
Im throwing this out as a thought and someone here may have the answer as to why its not done this way.
Why not use circuit breakers (appropriately rated) instead of fuses. You will have to build some kind of a housing to keep them in but it will keep you from ever having to replace a fuse again. Just pull over, wait for it to cool off and switch it back on kind of like a house system.
Other than that, it looks like the panel comes off in sections. Browse places like Digikey and see if you can find blocks of fuse holders. There are a ton of styles out there and im sure you can find one that will work.
You could wire these in and build a box to hold them
http://www.mouser.com/ProductDetail/Littelfuse/868-062-000/?qs=zHiv0nsVGmp8YI2jPiZzAg%3D%3D&gclid=COaQqbiRmr4 CFfEDOgodZwQAiw
or see what they have here
http://www.digikey.com/product-search/en/circuit-protection/fuseholders/655422
Regards
Dave
Clay.0 05-07-2014 08:41 AM
Definitely on my to-do list. Will be watching this one along with the others. Good luck!
timmy2 05-07-2014 09:24 AM
You could just buy one that is made up and ready to install from Fred Cook.
OsoMoore 05-07-2014 09:30 AM
I PMed him, this would be my first choice. I'm not sure if he's still selling them.
timmy2 05-07-2014 09:46 AM
He was last week in a PM he sent me.
OsoMoore 05-07-2014 10:02 AM
Excellent. After a bunch of looking, I couldn't find any way to get all 21 fuses in a nice tight line without gaps like he does.
I might be able to rig my own cheaper, but the kit looks worth the money and would be good to have that knowledge base to tap.
cabmandone 05-07-2014 02:30 PM
I've been going back and forth with my brother about updating the fuse panel. How much is the modern panel?
fred cook 05-07-2014 03:26 PM
This is where I chime in...........
Fred Cook here. Yes, still building fuse panels. At the moment, I can do them for 1969 thru 1989 911 and 930 cars. The 1974-89 panels come with 24 fuse positions instead of the stock 21 positions. This gives the owner some "spares" for future adds. I machine the bases from a piece of aluminum that is then covered with a type of adhesive lined heat shrink tubing. The fuse holders are added and then the appropriate jumpers needed to tie certain fuses together. The kits are available in two ways. First is the standard panel with the 24 fuse positions. This panel will fit under the stock fuse cover. The second option is a panel that is longer and is fitted with two additional relays for the headlights. Adding the headlight relay kit dramatically reduces the power that is drawn thru the headlight switch and the high low beam switch thus making them live longer. The kits include the fuse panel w/fuses, spare fuses, a fuse puller tool and instructions. Expect to spend about 8 hours or so doing the install. If you wish, instead of using regular fuses, you can use "smart" fuses that "glow when they blow" or even circuit breakers that will reset once a short is removed from the circuit. The smart fuses and circuit breakers are more expensive so you will have to buy those yourself. Costs.........the standard kit is $275 and the deluxe kit w/relays is $325.00. Expect it to take about a week from receipt of payment to shipping. Prices include shipping and insurance to any US zip code address. Out of the country is more. Hope this helps!
javadog 05-07-2014 07:03 PM
My advice is to just change the bad fuse block with another stock one. Leave the rest alone. You'll be fine for another 30 years. Longer, if you do a little periodic maintanence...
JR
wildcat077 05-07-2014 07:17 PM
I installed one of Fred's fuse panels over last Winter,a little nerve wracking but well worth it in the end.Fred is very supportive if you need extra parts or installation help !
Cheers
Phil
Algernon 05-07-2014 07:40 PM
http://forums.pelicanparts.com/porsche-911-technical-forum/772278-cheap-easy-ato-fuse-block-installation.html
This "Cheap and easy ATO fuse block installation " thread will save you most of time and money, especially as wires screw directly into new ATO block without needing to crimp several dozen quick-connects.
http://forums.pelicanparts.com/uploa...1399516815.jpg
So for 2 hours work and $30 this is a great improvement.
tirwin 05-07-2014 09:59 PM
I just got done installing Fred's fuse panel about 2 weekends ago. Cleaned up some nasty corroded wires and some hack jobs by some previous owner or mechanic. I wish I had done this sooner. I found a hairline crack in one of the fuse panels that was making a couple of the fuses loose. I never knew it until I took the old one out. I've been meaning to post some tips and lessons learned on doing this project. I will try to do that soon.
fred cook 05-08-2014 05:21 AM
Picture is worth a 1000 words............
Just in case someone has not seen one of my fuse panel installations, here's a picture of the one in my SC, both with and without the cover.
http://forums.pelicanparts.com/uploa...1399551547.jpg
http://forums.pelicanparts.com/uploa...1399551610.jpg
OsoMoore 05-08-2014 07:27 AM
I went ahead and ordered a 6 and a 15 fuse block. I'll see how it works out. For some reason, links to the 6 and 15 size blocks don't work, but you can see the 12 here, and get to the 6 and 15 from there:
FP-ATO-S12 ATO Blade Type Fuse Panel | Buy Online | Chief Enterprises
Cost $37.75 including shipping.
Spec info on these:
http://www.geppowerproducts.com/product/cview/ato_blade_type_fuse_panels
Robey5 05-08-2014 08:21 AM
This is an upgrade that I will be doing in the future.
I am going to watch this thread, as I have now had to deal with a fuse (in 3 different cases) being the fault - - not the fuse itself, but the connection between the fuse end and the holder. After seeing some of the (impressive) work by the fellow pelicaners; I can see that it will be an easy upgrade that will bring some slightly more modern technology to this car.
I love the solution that Fred made, and looks to be a bit more of a "plug and play" solution ... I may go that route.
ruwoodbury 05-10-2014 05:00 AM
I enthusiastically endorse Fred Cook's fuse panel. I read the instructions several times, including while looking at the old and new panels together. I called Fred a couple times before the install for clarification, he's terrific and patient. Gathered all the supplies and over the course of three days spent around eight hours doing a successful install.
OsoMoore 05-13-2014 09:49 AM
The fuse blocks arrived. Hopefully I'll have time tonight to tag wires and be ready to do the swap by week's end.
Algernon 05-13-2014 10:55 AM
When I did mine, I added 4 relays for headlights at same time. This saved 2 fuse positions, which I later used for oil cooler fan. Came in handy to have the extra fuse positions as fan takes large current and I did not want to add to an existing circuit. I ran a new feed from battery (through 25A fuse) for fan, and an 'ignition on' pickup to a 3A fuse to the fan controller. Hope this is helpful. If you need help, call three zero three 665-7336.
donporfi 05-13-2014 09:28 PM
Algernon
No problems or blown fuses since you installed the ATO fuse block ?
wwest 05-14-2014 06:37 AM
Lots of years ago, late 80's maybe, I replaced the fuel pump fuse with an inline fuse/holder. I have experienced NO other fuse block problems. 1978 Targa, fuse didn't fail, only the holder, and at the WORSE possible time.
I was first in line to get off the ferry as it docked...ended up trailing a line of traffic rather than leading it.
Ordered a new fuse block section, which I believe is still in the back of the glove box.
OsoMoore 05-14-2014 11:32 AM
Here are some quick pics from my current fuse box. Might be useful to other folks.
Linked because the PP board drops the resolution too much to be useful.
The labels here are what is printed on the cover. The fuse amperage is what I found in that slot. The amperage is not necessarily correct.
Fuse Box Cover Label
Code:
Base #        Label #        Value        Ganged        Label on Fuse Box Lid
1        1        25                window opener
2        2        Empty                air conditioner
3        3        16                head lamp washer system
4        1        8                total inter. light
5        2        16                warning light heated windshield
6        3        Empty                fuel pump
7        4        16                cig. light
8        5        16                run roof rear wind. wip
9        6        25                wind. wip and washer
10        7        16                air blow. rel.-heated rear win
11        8        ?                stop-turn-signal and backup light
12        9        8                blinker light front left
13        10        5                blinker light front right
14        1        8                high beam left
15        2        8                high beam right
16        3        8                low beam left
17        4        Empty                low beam right
18        5        5                parking light left
19        6        5                parking light right
20        7        5                license plate light
21        8        16                fog light
Fuse Box Image - High Resoultion
http://forums.pelicanparts.com/uploa...1400091392.jpg
Only fuses 3 and 4 appear to be ganged from the front. Further analysis with my multimeter and checking the back will determine which others are ganged.
A previous owner has messed with these - do not assume a normal SC should match this.
donporfi 05-14-2014 01:03 PM
From the back you will see this:
http://forums.pelicanparts.com/uploa...1400097525.jpg
Since you will use this type of fuse blocks
http://forums.pelicanparts.com/uploa...1400097758.jpg
I suggest that you check Algernon's post, he used the same fuseblocks.
fred cook 05-14-2014 01:22 PM
Connected fuse positions
Code:
6        3        Empty                fuel pump
7        4        16                cig. light
21        8        16                fog light
I believe that you will find that the following fuses are jumpered together on the top side of your old fuse panel. You can verify the info with a VOM:
16-17 Low Beams
14-15 High Beams
10-11 air blower- rear window and stop/turn signals
7-8-9 Cig lighter, rear wiper and windshield wipers
4-5 Interior lights and heated windshield warning light
This should be true for all SC cars (78-83). Hope this helps with your project.
OsoMoore 05-14-2014 01:23 PM
Hmm, I read Algernon's thread, but didn't see the immediate correlation to my stock SC fuse block. He has these funny "extra" top edge screw contacts which I don't, so I'm not sure mine is ganged in the same way as his.
Hopefully I'll have time to attack it tonight and see exactly what is going on on the back of it. The more I see, the more suspicious I am that serious re-wiring has happened in the past.
blucille 05-14-2014 01:43 PM
you are in for a lot of clean-up work, but I'm confident the outcome will be worth it. Note, you have no connections to any of the headlight fuses, high or low beam, no screws, no power in, or out.
The good news is it should be pretty straightforward to clean it up and make it work, it will be a little more involved to make everything work the right way. I am sure you will find, when you flip the stock fuse blocks over, you have the standard gang-arrangement, the wired-jumpers were put there by previous hacks
I'm assuming there are some headlight relays and fuses outboard of what your picture shows, and I also am scared by those two blade-fuses taped together, and the blue butt connectors under fuse 12 or so.
Can't wait to see the before & after photos.
OsoMoore 05-15-2014 07:26 AM
I took a first whack at the job last night. I removed the last original block, which has 8 of the fuses on it.
Of those, only numbers 18, 19, and 20 were actually used. 21 had wires to the bottom of it, but nothing on the top. I removed that block and replaced it with my 6 fuse block. I hooked up the wires into the same positions on the original block, including the unused number 21.
The original fuses were 5 and 16 amp. However I couldn't find ATO in 16 amp, so I'm using a 15. While this isn't quite correct, I don't foresee any issues with running slightly lower amperage fuses. Thoughts?
For now, the new fuse block is held in with wire ties. I plan to acquire a plastic ruler as a new mounting bar. I'll drill the rivets out of the new blocks, and epoxy them on to the ruler. Than I can drill holes in the ruler and mount it with the original screw holes.
This seems better than drilling new holes into the base plate, and putting tiny nuts on the backside.
I tested the three new active fuses (18, 19, 20) and they are correctly controlling the blinkers and license plate light. I suspect the taped wiring and fuses are relays for the headlights, installed in a poor way.
Before:
http://forums.pelicanparts.com/uploa...1400163476.jpg
In Progress:
http://forums.pelicanparts.com/uploa...1400163493.jpg
After:
http://forums.pelicanparts.com/uploa...1400163507.jpg
I put fuse 21's wires on the top instead of bottom. Doesn't matter because that fuse isn't used, but I should fix it.
OsoMoore 05-15-2014 07:47 AM
And an updated table based on my better pictures:
http://forums.pelicanparts.com/uploa...1400165273.jpg
fred cook 05-15-2014 08:41 AM
Mounting your fuse holders..........
Before:
In Progress:
After:
Go to Lowes or Home Depot and buy a 2" wide aluminum strip. Drill mounting holes in the aluminum strip and use bevel headed screws (from the back) to mount the fuse holders. Then you can simply drill holes thru the aluminum and use 4mm cap screws to mount the assembly to the bracket. This should be much more secure than gluing it together!
Algernon 05-15-2014 07:19 PM
Not sure what the 'extra top edge screw contacts' are you refer to? The extra red wires at the top are substitute for original hidden links.
Also, be aware the tops of the ATO fuses get very close to the fuse box lid - adding an al. strip or plastic ruler might stop the lid from snapping on. I used sheet metal screws to attach the holders directly to the fuse box frame where the original holes didn't line up.
If I can help, PM me, anytime.
http://forums.pelicanparts.com/uploa...1400206526.jpg
OsoMoore 05-16-2014 06:24 AM
Well last night I picked up a piece of aluminum at Home Depot for $8. I drilled out the rivets on the 15-fuse block. Then I marked out where I'll be attaching the little 3-mount fuse blocks.
I picked up some screws for attaching them to the aluminum strip, but the screws were too small so I'm going to need to pick up some more.
With the new strip, I should be able to also fit my two headlight relays. Also, I won't have to make any extra holes in the fuse mounting panel in the car itself.
http://forums.pelicanparts.com/uploa...1400246643.jpg
http://forums.pelicanparts.com/uploa...1400246657.jpg
fred cook 05-16-2014 07:16 AM
Much better........
Now you are on the right track! When doing jobs like this it is better to think "permanent" rather than "quick"! One thing you probably should check is the max amperage load per section. If you use 3 20 amp fuses in one 3 fuse section you might be overloading it. Better safe than sorry! Good luck!
Algernon 05-16-2014 08:54 AM
That's the best solution I've seen so far! Congratulations. I wish I had thought of de-riveting the fuse blocks and re-assembling them on a new strip! Maybe you could counter-bore the strip and re-rivet the fuse blocks on?
BTW, the fuse blocks are rated high enough to not worry about overloading them with 3 x 20A.
OsoMoore 05-19-2014 06:16 AM
I was pretty busy this weekend, but I did finish drilling out the mounting bracket, and got correct screws for attaching the fuse blocks.
Now I need to pull out the block I already installed, and then I can put the new one in.
Once it again works, I'll move on to mounting the relays properly.
http://forums.pelicanparts.com/uploa...1400505361.jpg
http://forums.pelicanparts.com/uploa...1400505373.jpg
The alignment isn't perfect, but its pretty close!
And here's what kept me busy Sunday - waxing that baby!
http://forums.pelicanparts.com/uploa...1400505406.jpg
OsoMoore 05-21-2014 06:27 AM
She's done!
Before
After!
http://forums.pelicanparts.com/uploa...1400678593.jpg
It was a real pain getting some of the bigger gauge wires into their spots, but I eventually got them. I used very large gauge wire to make the necessary gangs. I was able to reuse the gang that was originally from slot 3 to 4.
The screws I used for holding the fuse blocks onto the mounting strip were #10x1/2"
In the end, it took about 3 hours to connect the wires, gang the necessary ones, and then double-check every connection, fuse value, and gang.
But she works great, and it is much cleaner now! Next I need to take out that messy relay setup and mount those relays and fuses in a professional setup.
theiceman 05-21-2014 06:57 AM
Could you expand on this ?
Adding relays does not remove the necesity to fuse the headlights. Of course you wouldnt fuse for the milliamps running throught the switch but you would still need to fuse the power on the secondary side of the realy that is feeding the lights. Unless of course you meant that your fuse for the lights is elsewhere now that you have the relay .
Joe Bob 05-21-2014 10:18 AM
A well written DIY article would be most likely an addition to the PP brain trust. I have been thinking about the upgrade myself.
santagrant 05-21-2014 10:53 AM
After reading the many responses, spending the money with Fred Cook would be the most efficient use of your time and effort. His prices seem reasonable to me.
Grant
Algernon 05-21-2014 08:28 PM
Yes, I used 4 relays with built-in ATO fuses! The 4 feeds to drive the relays came from the switch via 2 original fuse lines, re-fused to lower value, saving 2 positions. The power to each relay came through 4 dedicated new lines direct from battery. So no lines, fuses or relays have to cope with more than 1 filament.
The 2 yellow and 2 white wires coming from fuses 5 and 6 go to relays, leaving 7 and 8 which I then used for oil cooler (red and yellow wires). Hope that's clear?
http://forums.pelicanparts.com/uploa...1400728729.jpg
http://forums.pelicanparts.com/uploa...1400728795.jpg
http://forums.pelicanparts.com/uploa...1400728916.jpg
(I ran out of red fuses for the relays, hence temp. blue one!)
Algernon 05-21-2014 08:37 PM
Grant
I'm not knocking Fred, but I just could not bring myself to add quick-connects to every last wire going to the fuse block! My back would not stand it, and I was not sure if this would create another source of uncertainty if my crimping was not perfect. The original Porsche wire ends just pushed directly into my new fuse holders in most cases. A few big reds needed help. Less work and 10% of cost worked for me. YMMV.
