-   -   injector size (http://forums.pelicanparts.com/porsche-911-technical-forum/8101-injector-size.html)
911juiced 09-11-2001 03:33 PM
injector size
what size of injectors are in a 911 3.2 motor
also can i upgrade them to what size?
Superman 09-11-2001 03:36 PM
Some say that size does not matter.
'83 SC
Bill Verburg 09-11-2001 03:44 PM
flow rate of 84-86 injector is 22# per hour. 87-89 may be the same..or very close
<font color="#730000">Bill Verburg</font>
My Home Page http://www.pelicanparts.com/ultimate/icons/icon15.gif My Pelican Gallery page http://www.pelicanparts.com/ultimate/icons/icon15.gif My Porsche Owners Gallery Page
Superman 09-11-2001 04:25 PM
I was making a joke. Or trying to.
You don't want to put injectors in the car that are not designed for the system. If you were to desire a richer mixture, that is an adjustment. If you increase displacement such that the old FI system is not metering the fuel properly, then you need a different Fuel Distributor. Not different injectors. At least that is my conclusion.
'83 SC
911juiced 09-11-2001 04:35 PM
can i put a 30pounder injector on my 3.2?
ChrisBennet 09-11-2001 06:49 PM
<font face="Verdana, Arial" size="2">Originally posted by Superman:
</font>
He has a 3.2 which has no fuel distributor.
movin 09-12-2001 09:01 AM
Thought someone said the 944 injectors were better because of spray or atomization and they're a performance improvement to the Carerra Series.
Jim Smolka 09-12-2001 11:53 AM
I would not install 30 #/hr in a basically stock 3.2 The O2 sensor is basically there to keep the air to fuel ration at aprox 14.7 to 1. The correction factor of the O2 sensor feedback probably would not be enough to maintain that ratio.
With the additional fuel may actually reduce HP since the most HP is developed with an air to fuel ratio of aprox 12.5 to 1 (lots of variables here).
Also, the additional fuel might damage your motor (washing the cylinders and fuel in the oil)
