Post injector size
what size of injectors are in a 911 3.2 motor
also can i upgrade them to what size?
Old 09-11-2001, 03:33 PM
Senior Member
Superman's Avatar
Post
Some say that size does not matter.
'83 SC
Old 09-11-2001, 03:36 PM
Bill Verburg's Avatar
Post
flow rate of 84-86 injector is 22# per hour. 87-89 may be the same..or very close
Bill Verburg
My Home Page My Pelican Gallery page My Porsche Owners Gallery Page
Old 09-11-2001, 03:44 PM
Senior Member
Superman's Avatar
Post
I was making a joke. Or trying to.
You don't want to put injectors in the car that are not designed for the system. If you were to desire a richer mixture, that is an adjustment. If you increase displacement such that the old FI system is not metering the fuel properly, then you need a different Fuel Distributor. Not different injectors. At least that is my conclusion.
'83 SC
Old 09-11-2001, 04:25 PM
Post
can i put a 30pounder injector on my 3.2?
Old 09-11-2001, 04:35 PM
Irrationally exuberant
ChrisBennet's Avatar
Post
He has a 3.2 which has no fuel distributor.
Old 09-11-2001, 06:49 PM
Post
Thought someone said the 944 injectors were better because of spray or atomization and they're a performance improvement to the Carerra Series.
Old 09-12-2001, 09:01 AM
Jim Smolka's Avatar
Post
I would not install 30 #/hr in a basically stock 3.2 The O2 sensor is basically there to keep the air to fuel ration at aprox 14.7 to 1. The correction factor of the O2 sensor feedback probably would not be enough to maintain that ratio.
With the additional fuel may actually reduce HP since the most HP is developed with an air to fuel ratio of aprox 12.5 to 1 (lots of variables here).
Also, the additional fuel might damage your motor (washing the cylinders and fuel in the oil)
Old 09-12-2001, 11:53 AM
