jrenfrew's Avatar
How can I tell if my ball joints are the early or late style? Can you provide details on when the transition occurred?
This post was auto-generated based upon a question asked on our tech article page here:
James Renfrew
75 Porsche 914
78 Porsche 928
Old 05-08-2014, 06:49 PM
Nick at Pelican Parts's Avatar
Try this link:
- Nick
djpateman's Avatar
If you are thinking of the 911/914 change back in 1972, then a quick visual inspection should tell you. The early ball joint used a split bottom strut with a nut and bolt to pinch the pin to the ball joint into the strut; if you can see the head of a bolt then this is the one. The later ball joint was fastened with a wedge pin, and you will only see the nut holding it in place.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 05-09-2014, 04:18 PM
