-   -   Help with electrical problems with CDI and delayed action relay (http://forums.pelicanparts.com/porsche-911-technical-forum/810146-help-electrical-problems-cdi-delayed-action-relay.html)
wgwollet 05-07-2014 05:08 PM
Hello
I have a 1978 turbo 930, I get no spark....
I checked voltage to the delayed action relay in the engine bay (silver box relay), I only get 12v to the pin from the alternator, the switched 12v, I cannot get voltage. This line feeds power to the CDI #15 pin. I pulled the delayed action relay off and tested on another car it's fine...
Does anybody know what I am talking about, I cannot get power to the CDI box, from the relay, the relay has a brown wire (ground), white, red, 2 red/white, another one too.
Where does the switched 12v come from, my wiring diagram I can figure out.:confused:
Thanks in advance. :confused:
wgwollet 05-09-2014 05:11 PM
Bump ...help
john walker's workshop 05-09-2014 06:45 PM
it has direct battery power at all times. key on power from the ignition switch via fuse 12. you can jump the relay plug itself with a short wire with spade terminals, bridging the two wires in the plug that are closest to the engine. remove the relay to do it. 30 to the L terminal.
wgwollet 05-09-2014 07:27 PM
Thanks John
