Help with electrical problems with CDI and delayed action relay
Hello
I have a 1978 turbo 930, I get no spark.... I checked voltage to the delayed action relay in the engine bay (silver box relay), I only get 12v to the pin from the alternator, the switched 12v, I cannot get voltage. This line feeds power to the CDI #15 pin. I pulled the delayed action relay off and tested on another car it's fine... Does anybody know what I am talking about, I cannot get power to the CDI box, from the relay, the relay has a brown wire (ground), white, red, 2 red/white, another one too. Where does the switched 12v come from, my wiring diagram I can figure out. ![]() Thanks in advance.
Bump ...help
it has direct battery power at all times. key on power from the ignition switch via fuse 12. you can jump the relay plug itself with a short wire with spade terminals, bridging the two wires in the plug that are closest to the engine. remove the relay to do it. 30 to the L terminal.
Thanks John
