wire Distributor
I have a 1980 911 SC that I need to replace the distributor wire from the distributor to the CDI box . I ordered a new one and it came much shorter with a fitting conector on one end. Mine runs all the way from the distrubutor to the CDI box . Is there another wire that I need to order to run from the connector to the CDI box? If so what is the part number. This new wire will not run to the CDI box
Old 05-17-2014, 12:06 PM
ROW '78 911 Targa
timmy2's Avatar
The replacement for the CDI green wire requires you to cut the existing green wire and install a timer Jr. connector to plug the new one into.
The method for doing it has been posted many times. Search "green wire repair".
Eagle day sells a kit for the connector with terminals and the boot.
2-Pole Female AMP Connector
Or, I can send you the same thing for $12 shipped. PM me.
Old 05-17-2014, 01:25 PM
ROW '78 911 Targa
timmy2's Avatar
Here a post I made a while ago about the replacement of the green wire and how to do it.
Distributor Green wire loose and frayed
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 05-17-2014, 02:54 PM
