-   -   I hate gauges that don't show temp. Is this too warm?? (http://forums.pelicanparts.com/porsche-911-technical-forum/810599-i-hate-gauges-dont-show-temp-too-warm.html)
alfisti 05-13-2014 05:12 AM
seems like my sender is an oddball part number. I don't see any mention of it online. It is labeled 911606112000. It is also clearly labeled 200°C.
My gauge has markings at 60, 90, 120 and 150. Is it the right sender?
I will get a thermometer today.
-Glenn
Joe Bob 05-13-2014 05:29 AM
Hand held pyrometer.....cheap and easy.
cabmandone 05-13-2014 11:22 AM
-Glenn
I think you've got one too many zeros at the end. Your part number is the same as the one I just ordered but with one less zero.
Here's the part I ordered which is right for the newer gauges according to the PP site. 911-606-112-00
javadog 05-13-2014 11:50 AM
Don't think so...
JR
toddu 05-13-2014 12:44 PM
That sender works with the older gauge with 60 90 150 170 (long red area at top).
Todd
alfisti 05-13-2014 02:24 PM
Here is the gauge I have: http://forums.pelicanparts.com/uploa...1400016200.jpg
toddu 05-13-2014 02:57 PM
I just bought that same sender for my '81 SC, and that's not the gauge I have. I think there are 3 flavors of gauge and would think they each have their respective sender?
Todd
PS - that looks like about 225ish. After how long driving?
alfisti 05-13-2014 06:25 PM
They is after idling in the garage with a/c on. It got hotter than that... It got even with the top skinny line
Sent from my RM-877_nam_att_205 using Tapatalk
cabmandone 05-14-2014 08:16 AM
alfisti,
I'll let you know what numbers are on my new sender when it arrives. Have you put a thermometer in the tank to check actual oil temp? While my gauge indicated the oil would have been in the high range, the thermometer only showed 180.
alfisti 05-14-2014 02:54 PM
I bought an IR thermometer... Where do I point it for an accurate reading? Thx
Joe Bob 05-14-2014 02:56 PM
Like a gun......where you want a reaction.....
Ronnie's.930 05-14-2014 03:09 PM
Ha - awesome! :D
alfisti, the bottom of the oil tank is a good place to start.
Reiver 05-14-2014 06:52 PM
Originally Posted by Ronnie's.930 (Post 8064655)
Ha - awesome! :D
But move it around a bit for the highest reading...it also depends upon the size/width of the laser beam...the inexpensive ones have a pretty large spread but it'll get you in the ballpark.
Works best on dark surfaces as very bright shiny bits can reflect the beam.
alfisti 05-15-2014 09:37 AM
So, I checked with the new thermometer and it seems roughly accurate? Check out the highest reading... 93.3. Looks pretty close?http://forums.pelicanparts.com/uploa...1400171834.jpg
toddu 05-15-2014 10:16 AM
Gauge seems high to me. First line is 90 right?
Todd
alfisti 05-15-2014 10:59 AM
Yes. The gun says 93.3... Also, that was measured off the bottom of the oil tank. I would think the crankcase would be a couple of degrees higher. What is everyone else seeing?
cabmandone 05-15-2014 11:55 AM
Success! I installed the new sending unit and drove. The gauge never got above the top of the first line. It's only in the 50's here today but even on days like today the car would show that it was running closer to the top white line than the middle line.
When I pulled the old sending unit the date was 12/74 which would make sense being the PO was going to put a 74 or 75 gauge in the car he was going to use the 3.2 in.
