I hate gauges that don't show temp. Is this too warm??
My car always seems to run in about the range of where the needle is when it's between about 75 and 90 F ambient. Is this normal? I really hate gauges with lines and no numbers to correspond. I had a gauge that showed temps but sold it and now I'm wishing I had kept it and installed it.
FWIW, I haven't seen the temp go above this point in town driving or on the road but the engine has only been in the car since last August so I have no baseline. http://forums.pelicanparts.com/uploa...1399772482.jpg |
If the gauge and sender are both accurate (a big if), that corresponds to about 120°C, or around 250°F. A little on the warm side compared to my '84. Mine has never gone that high. Warmest I've seen is about 110°C (230°F) on a 90°F day with the A/C running.
Side note. Adding numbers to the gauge you have isn't hard. Still no guarantee that it's accurate, though. Check 911 Gauge module overlays for °F. I wanted Celsius for mine so I made my own gauge face. Post from my car's thread. |
That is way too hot. Should be at or a tad above the lower line
Corresponding numbers are on extreme left of the display. Take a peek obliquely. Also, perform a Google search, "Pelican SC oil temperature gauge" for several threads on this subject.
As mentioned, your engine is running too hot. Possibilities include malfunctioning sending unit, gauge or thermostat (engine and external), loose fan belt, obstructed air flow path (engine and/or external cooler), etc. Sherwood |
Getting a bit warm going by the gauge given your ambient temp.
I tackled the same issue by yanking out the trombone pipe and adding a big cooler and one heck of a fan. Going by my gauge the thermostat seems to open when the gauge gets about half way, then it wont get much more. Before that it would get real hot in the Summer. |
I changed the senders and put the overlays on several years ago. This should take care of your problem going forward.http://forums.pelicanparts.com/uploa...1399776443.jpg
This is way too high. Is it possible that the switch that allows the oil to go up front to the radiator does not work ? My 1985 has never gone that high.
Just this afternoon, I drove the 86 Targa with the AC running from Phoenix at 1,000 ft up I-17 and SR 69 to Prescott, elevation 5,500. Ambient temp in Phoenix was low 90's, and I was doing between 70 and 85 up the mountain inclines. Temperature never exceeded the mid point of the gauge, or about 220. If you're experiencing higher temps than that without pulling mountains or running the AC, it seems to me that all is not quite right. I would check the entire cooling system including the thermostats. If the oil coolers and thermostats check out okay, I would stick my boroscope in the openings in the cooling shroud and make sure there isn't a rats nest in there!
Gauge overlays are available from newvintageusa.com and are easy to install yourself. It is useful to purchase an IR thermometer hand held. Can check temps at various points at various times. They are inexpensive. Amazon. Your temp indication is high.
I guess I've got some searching to do on why my car is running this warm. I put in a new front cooler as my brother had removed the original from the car. Is it possible my front cooler thermostat is stuck? I'll look into the temp sender. I replaced the pressure sending unit a while back because the engine from my donor car came setup with a earlier gauge that showed temp and pressure in numbers like the one pictured in post 6. I'll have to look into where the temp sender is located and see if it too is wrong for the gauge.
Thanks for the replies. |
When my '87 started getting that high it was usually in traffic. I found the wire to the front cooler fan broken. Once I fixed the wire everything went back to normal.
For the record, regardless of ambient, I have never seen the gauge move above this point. It warms up to this and doesn't get any closer to the red. I found my sender. I'm going to order a new on since the one in the engine is most likely for the early gauge. I also found that my fan belt is a bit loose so I'm going to re tighten the belt and drive it today. I suspect the sending unit is going to be the problem because the car ran this temp last summer and fall when the belt was first installed and tight. Belt is tightened, waiting for fog to lift to go for a drive then I'm going to check lines to the cooler to see that they are getting warm. Again, I really appreciate all the input. |
With it running that hot, you should be able to reach under the passenger front wheel and feel a very hot cooler and oil lines. You can tell by feel if the thermostat is opening.
You have some other wackiness going on. Your oil pressure is low (not horrible for fully warm at idle) and your oil level is very high. What oil are you running and was the engine recently rebuilt? |
First you need to verify that that's the actual temperature before taking any action. Get a cheap digital meat thermometer get the car warmed up put the probe in the oil tank to check the oil temp.
Definitely check the part number on the sending unit first. Takes 30 seconds...
JR |
As for pressure, from what I've read that's completely normal for a 3.2 at idle. 800 to 900 rpm idle corresponds to about 1 bar. Quote:
It's common for the oil lines going to the front cooler to get crushed where they go around the jacking point. This is easy to check by looking at the lines by the right jacking point.
The front cooler fan should come on when it reaches the line it's at, around 240F. I can hear when mine comes on. Mike |
You can see the part number without removing the sending unit. Takes longer to open the engine lid...
JR |
Also,
Check the tension on your fan belt, it may be a simple case that the fan is slipping! Hope this helps.:) Anthony. |
Fan belt has been appropriately tightened. Thanks again everyone. |
+1...check that the sending unit and oil temp gauge are a match. This is common reason for incorrect temp readings.
regards, Al |
I better check mine out too. Good thread...
Sent from my RM-877_nam_att_205 using Tapatalk |
UPDATE:
Took it out, drove it easy to let it get warmed up then drove it :) Temp gauge went up to about the range shown on in the first post. Fan belt was tightened, ambient is about 78 F. Put my long Brewing thermometer that goes up to 220 in the oil tank (how much do I love this car?). Got to 180 and stopped. I couldn't see a number on the temp sending unit but since I want to get a headlight relay kit from the sponsor, I'll just order the temp sending unit with that. |
+1 too high let us know f you have crushed lines. I would get a IR temperature reader and check the actual temps at the thermostat at the passenger side rear wheel well, the hotter one is coming from the engine.
Mine goes right below that hash mark in the summer. in heavy stop and go traffic, as long as you stay in between the two middle hash marks you are good. Normally at full operating temp, mine will stay at 1/8 inch about the first hash aka 8 o Clock. What weight of oil are you using? |
JR |
Looks like you found your problem. Congrats!
Here's the one I find on the P.P. site http://www.pelicanparts.com/catalog/SuperCat/0806/POR_0806_ELSENS_pg2.htm#item6 I don't see any other option for my car and this is the 85 gauge. |
I'm guessing that you have gauge number 911 641 923 00. You probably need sender 911 606 112 00. I'd still take a look at the one you have, first. With a flashlight and a mirror (wrost case, may not be needed) you should be able to read the part number. It's stamped on the sending unit.
JR |
This thread hurts...
Fully solidifies that my SC is running to dang hot. Hopefully, the new t-stat will remedy this. |
cabmando -- Have you checked the temp of your front oil cooler lines when the engine's hot (i.e. simply checked to confirm that the front oil cooler lines do get hot?) Sounds like the wrong sensor's the root cause of your problem, but while you're getting this together, also important to confirm that the thermostat that lets hot oil flow to the front cooler is, in fact, working.
If the temp sender is brass, then its early, pre 77 with a 901#. If its chrome covered, its post 77 with a 911 #
Bruce |
So, my gauge showed high... At 10 o'clock, while idling in the garage with the a/c on. The front oil cooler lines never got hot. The oil level gauge did eventually rise to near the top, though. So the engine really did at least get warmer. I am wondering if the thermostat is not working, and/or my server is inaccurate. Where can I find the sender? Is there an article I refer to? Thanks all
Ugh, I was getting the hours on the wrong side, on the drivers side. Oy. Warning the car up now to see how it behaves...
Fwiw, I had the same problem. Gauge was reading high relative to infrared thermometer readings on the engine, oil lines near engine and auxiliary oil cooler lines. I sent my gauge to north Hollywood speedometer. They replaced the oil temp movement and provided a matching new sender for $165 shipped. Went from reading 230F and panic attacks to 185F.
Sorry for the bad autocorrecting. I was feeling the hoses ion the wrong side of the car. I let the car get hit just now, the temp went to just shy of 10:00, and settled back a bit. I felt the hoses on the PASSENGER side (sigh) and they were hot.
Oddly though, earlier in the day, the engine got a lot hotter. It was warmer out then, but not by much. I am still uncomfortable with how hot it got before I shut it off. I will check the sender and gauge combination tomorrow. |
| All times are GMT -8. The time now is 06:39 PM. |
