Ferrino's Avatar
Fuel & Oil Level Sender Gaskets
I see that there are cork and rubber gasket variants for both the oil level and fuel level senders. Is there a preference for either?
Rubber gasket
Cork gasket
Old 05-14-2014, 11:35 AM
Dave Colangelo's Avatar
I used the cork on my oil level sender and have not had any problems since changing it 4 years ago. I dont see why any one would be better than the other. Maybe there is some difference at high temps but I assume something else will go wrong before your oil heats up to the point of ruining one of these gaskets.
Regards
Dave
'78 911SC Targa (Back In Action!)
'00 996 Carrera (New kid on the block)
'87 944 (college DD - SOLD)
'88 924s (high school DD - Gone to a better home)
Old 05-14-2014, 11:57 AM
Ferrino's Avatar
Thanks. I thought I read somewhere that one was an update of the other.
Old 05-15-2014, 09:50 AM
Member 911 Anonymous
DRACO A5OG's Avatar
I used cork, on the oil sending unit. The trick is in torquing it. Apparently the OEM specs are not in enough. I had to go a bit more to keep it from wheeping at the seal
'85 Carrera Targa
PCA/POC
Old 05-15-2014, 10:47 AM
Location: Just a little north of 13669/Nation's capital
Send a message via AIM to brighton911
I also used cork on the oil sender, maybe a little extra torque but no issues.
Old 05-15-2014, 10:53 AM
E Sully's Avatar
I used cork on the oil sender and rubber on the fuel tank sender. No problems with either.
Ed
1973.5 T
Old 05-15-2014, 11:04 AM
