O2 sensor removal question
There are two sets of wires that go to the O2 sensor. One is a three pin and the other is a round connector. The three pin pulls straight out but the round will not budge. Does it just pull straight off or is there a trick? I don't want to damage anything. Please let me know how to disconnect this connection please! thanks. Joe
1985 911 Targa 3.2 with 964 Body Kit
Old 05-16-2014, 01:57 PM
Peel/roll the rubber protective cap back, then pull on the wire.
The Cap'n
Old 05-16-2014, 02:12 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Pull straight out, the part mounted to the chassis is very brittle, try you best not to damage it. It has seen allot of heat. Try some spray lube then pull gently
'85 Carrera Targa
PCA/POC
Old 05-16-2014, 06:00 PM
I would probably cut a slit in the rubber boot, then gently peel the boot off. Otherwise, you may crack the insulator plug, as already pointed out.
Old 05-16-2014, 06:19 PM
