Jp-oh's Avatar
Bulb Fell Into Speedo - Me Spazz
As in the title, one illumination bulb fell into the speedo because I was rushing when removing it. I am not really in the mood to pull the speedo apart at the moment. How big a deal would that little bugger be. From my recollections of the speedo's guts I'd be surprised if it got up to too much trouble in the short term.
1986 Meteor Grey Carrera - We'll meet again in Valhalla.
Old 05-16-2014, 11:35 AM
Dave Colangelo's Avatar
if memory servers there is some space in the back there between the guts and the back of the metal housing. It should just fall to the bottom and stay there but if you drive aggressively it may shift around a bit. I dont see any reason it would cause an issue unless it somehow got tossed up into the moving parts of the ODO. The Speedo functionality should remain unaffected as that stuff is well protected.
Regards
Dave
'78 911SC Targa (Back In Action!)
'00 996 Carrera (New kid on the block)
'87 944 (college DD - SOLD)
'88 924s (high school DD - Gone to a better home)
Old 05-16-2014, 12:16 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Yes, there is access but the green wire is really short, take care not to pull to hard or speedo will be disabled.
You could de-solder and re-solder carefully.
'85 Carrera Targa
PCA/POC
Old 05-16-2014, 12:20 PM
TheSt|G's Avatar
It might be possible for it to create a short from a live wire to the speedo housing.
I did the same when was rebuilding the gear on my odometer. Fortunately it was before I took it apart!
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs
2005 E46 M3- Daily Beater - 3350lbs
Old 05-16-2014, 12:26 PM
Michael T's Avatar
I had this happen. Get a toothpick and wrap duct tape backwards (sticky side out). Took me about five minutes to fish it out. I was envisioning a trip to North Hollywood Speedo. Problem solved.
1987 928 S4 - Black
2014 C4s 991 - Agate Grey
2014 Cayenne - Mahogany metallic
Old 05-16-2014, 01:18 PM
