Shaun @ Tru6's Avatar
What MFI lines did I buy?
I bought these MFI lines, pump bases, solenoid, and cross bar here on Classifieds.
The lines don't look at all like my 69 ones. Do you recognize them? Crossbar too. For a later model?
Tru6 Restoration & Design
Old 05-19-2014, 10:04 AM
Friend of Warren
Are you sure they are 911 MFI fuel lines? They just don't look right. See if they match up at all to this illustration:
Kurt V
Old 05-19-2014, 10:30 AM
tobluforu's Avatar
Can't help, but you sure have a nice selection of plated bolts, etc..
Old 05-19-2014, 10:49 AM
TheSt|G's Avatar
My thoughts exactly. That is some sexy spare hardware.
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs
2005 E46 M3- Daily Beater - 3350lbs
Old 05-19-2014, 10:54 AM
The set dead center in the lower picture look suspiciously like the ones on a mid-'70s-early '80s VW diesel, right down to the anti-vibration clamps.
The Cap'n
Old 05-19-2014, 11:09 AM
There is 2 different styles that go to the right bank and it has to do with clearing the grey air channel on the later cars.
Bruce
Old 05-19-2014, 11:17 AM
BlueWing's Avatar
Yes under the black bin are VW. Here is a pick of my spares.
79 SC Minerva Blue ROW
Non Sunroof Crank Window Coupe
3.0 SSIs, Backdated Heat
COA: Passenger Side Mirror, Manual Antenna & Dunlop Tires
Old 05-19-2014, 11:29 AM
BlueWing's Avatar
The VW lines picture would help.
Terry
Old 05-19-2014, 11:31 AM
Thank you Terry, do you think some of the long lines are VW diesel as well? 3 of them have the same nut as the the short injector lines.
Old 05-19-2014, 03:48 PM
BlueWing's Avatar
Shaun, the other lines I can't be sure of. I was looking for pictures of my old Mercedes 300CD, 5 cylinder diesel. It had similar injectors and just thinking out loud that similar connectors 5 pipes?????
Anyone with a 70s/80s era 3.0 MB diesel can maybe peek.
If I find any pics I'll be back.
Terry
Old 05-19-2014, 04:04 PM
Lots of injectors use the same thread for the coupling. I just cleaned a set of 2002 Tii injectors on a diesel machine. VW diesels of that type (pre-TDi) all share the same configuration. The only other VW option might be the Audi 5000 diesel and turbo diesel. Volvo used a similar engine configuration. They could also be for one of the many MB diesels.
The Cap'n
Old 05-19-2014, 04:16 PM
Wanted to thank everyone and close this out. Seller issued a partial refund, very gentlemanly.
On the plating, it's a rabbit hole that has no end. But so glad I kept all hardware on every car I ever parted out. Now I just wish I had those cars back.
Old 05-20-2014, 05:06 AM
