CV bolt play in transaxle flange?
Before I took apart my transmission, I had a look at the threads in the transaxle flanges. They were all a little torn up so that I couldn't screw in a CV bolt. I chased one with a thread chaser to clear out the bits and clean up the threads. The threads look clean and they grip, but I'm paranoid that the bolt I inserted has too much play. I have moon plates and serrated washers. I realize it's the tension of everything assembled that holds things together, but I don't remember how much play there was before the threads were damaged. Is this something I should be concerned about? Or should I proceed with the others?
here is a 4-second video that shows the play.
Video May 16, 8 22 59 PM - YouTube
1983 SC
Blog
Old 05-16-2014, 08:55 PM
SchnellSchweitz's Avatar
Do it right... Dump the OEMs for these Ideola's Garage: Stage8 Fasteners for Porsches - Application Guide
More info: https://www.youtube.com/watch?v=Nu8kTzLbpmA
'82 SC 3.0L Targa, Chiffon/Brown
“It all began when I was looking around but couldn’t find the car of my dreams anywhere. So I decided to build it myself.” - Ferry Porsche
Old 05-16-2014, 09:15 PM
Thanks, SS. Looks like those bolts are threaded as well.
1983 SC
Blog
Old 05-17-2014, 11:34 AM
Send a message via Skype™ to Porboynz
I just happen to have a driveshaft off to change out a CV boot. Was that bolt in the video in the full depth? Assuming yes it is then it is fairly loose compared to mine which has a maximum 2mm sideways movement when screwed in to a point just before the threads protrude through the other side. The video looks like about 3-4mm side slop. Still, if the threads are good enough to allow the cap screw to be torqued up correctly then side slop is not going to be a big issue. You would want to check the torque after driving a few times to be sure. Those Stage 8 fasteners sure are nice, I had a CV bolt snap once and caught it walking out of the CV housing before it damaged something when I saw it while swapping on a set of wets between races, very scary.
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 05-17-2014, 09:46 PM
Yes, that's in all the way. I think it's more like 2-3mm. I decided to make a chaser from a used bolt with three channels cut into it. After cleaning out the threads with the used bolt, a new bolt fits very snugly. I'll chase the rest of them with this.
Yep, the Stage 8s look like a great idea. I've not had a problem with these bolts backing out, but if I do I'll get a set.
Thanks for the replies!
1983 SC
Blog
Old 05-19-2014, 04:22 PM
