-   -   Non-working AC thread #3141592 (http://forums.pelicanparts.com/porsche-911-technical-forum/812416-non-working-ac-thread-3141592-a.html)
COLB 05-22-2014 05:19 PM
I say, do the $300-500 refresh and get some practice. If you want to put one of Charlie's systems in, you will have some flight time under your belt.
To expand on Bob's point, of the $300 I mentioned, $150 of it was the vacuum pump and the gauges -- which you are going to need if you DIY a full-on modern aftermarket system -- so that is not wasted money, even if you later decide to "go big".
Bob Kontak 05-22-2014 05:31 PM
Also, you will gain lots of new friends in the "hood" with your new gear. July especially.
I can't recall if I mentioned the 30lb R134 tank for $100?
JAR0023 05-22-2014 05:37 PM
Originally Posted by Pato911 (Post 8078443)
A couple quick clarifications/ updates:
1) The picture of the drier is very misleading. It is filthy! My car will never be a garage queen and has sadly not been washed in a couple weeks. The drier is straight with no bends, dents, etc. That said, it does look OE and I will plan to replace it.
Originally Posted by Bob Kontak (Post 8078546)
Not buying it. That thing is tore up unless flat does not count as distortion. Moot as OP is replacing, I hope.
I was trying to point out with pictures what several here failed to comprehend in words. Might want to check the prescription on your beer glasses. -J
http://forums.pelicanparts.com/suppo...s/beerchug.gif
firemedyc 05-22-2014 05:40 PM
I just had my compressor replaced. The clutch was engaging and compressor was hot. They told me that I had a blockage as well. Replaced compressor dryer and expansion valve. It was blowing at 47 degrees after that.
Good Luck
crownarch 05-22-2014 06:04 PM
Just this week when I had all my A/C hoses pulled off and was thinking, hey I have a friend who works at our local Parker store and figured I could save a ton of money. So, ran down there with all the hoses and I thought he was going to choke. First of all, they didn't even carry more than half the hose fittings. Second, they would have to cut the "U" shaped fitting that is used on the rear condenser and weld a tube in ($75 - $100 for the weld). Then he says in a nice way, "this isn't a job, it's a project and can't even quote you a price". I sheepishly grabbed my hoses and went home with my tail between my legs. I ate a lot of crow and then called and ordered a new set from Kuehl. Cheap? no, but then you always get what you pay for.
Bob Kontak 05-22-2014 07:26 PM
It looks dented. What can I say? I'm a loser, so why don't ya kill me.SmileWavy
FWIW. On a definite side note, my daughter and I visited the U of Texas two years ago. She shot pics of the clock tower area where they were trying to take out Charles Whitman. She had a fancy camera. She did the reverse Heisenburg uncertainty principle thing like you did with the dryer pic and the holes in the structure really became clear.
LM3929 05-22-2014 07:59 PM
Sorry to Hijack this this thread but I will shortly (within the next 10 month at my rate of getting things done) be rebuilding my A/C system with barrier hoses but using Freon and in looking for a new drier.
Pelican shows 3 starting at $36.00 to $170.00 why the big difference?
Thanks Lorne M.
wwest 05-22-2014 11:39 PM
A C Receiver Drier UAC RD 10108C Fits 84 89 Porsche 911 3 2L H6 | eBay
kuehl 05-23-2014 05:44 AM
Originally Posted by LM3929 (Post 8078978)
...... looking for a new drier. Pelican shows 3 starting at $36.00 to $170.00 why the big difference?
$170 gets you an OEM o-ring type, good for 1984-1989 years.
$36 gets you an aftermarket o-ring type, good for 1984-1989 years.
$69 gets you "Kuehl" which can be used for flare or o-ring types, 1969-1989,
certified to work with either R12 or R134a (having XH9 type desiccant), plus
installation instructions and other necessary items related to drier install, and
technical support from Kuehl.
Pato911 05-23-2014 03:22 PM
Apologies. I had the day off and spent it on sleeping in, golf and lots of beer. No Porsche for me.
I will not, however, leave you empty handed. For those more willing to interpret images over my statements, I squirted a bit of water and wiped down the drier... still not dented.
http://forums.pelicanparts.com/uploa...1400883476.jpg
Just for your entertainment as I fully intend to replace it.
Tomorrow, I will try to put some gauges on the system and/ or go back to the original shop (although I am beginning to not trust them).
When sober, I will also order up some parts as I try not to mix drinking and online purchase mode. :)
Have a great weekend everyone!
Bob Kontak 05-23-2014 03:41 PM
A picture is worth a thousand words they say.
Sorry I misinterpreted it.
I am glad you are going to tackle this yourself.
rusnak 05-23-2014 03:52 PM
Kuehl stuff is top-notch. Just don't mis-spell his name or he'll slap you. I think you should change the expansion valve while you change the receiver/drier.
kuehl 05-23-2014 04:14 PM
"camera lens distortion or some funky picture editing going" lol!
kuehl 05-23-2014 04:27 PM
When I'm sober, I will also order up some parts as I try not to mix drinking and online purchase mode. :)
Oh, that's why the picture was distorted. Yup, happens to me if I
drink Bud instead of Becks.
Pato911 05-24-2014 10:59 AM
Hah! Only cleaning after drinking.
Quick update. You can borrow gauges from autozone for free and I got a brand new set. I accidentally released a bit to atmo getting the dang low side connected but at rest the system was 55# and running with controls maxed and at idle it was 10/100#. Also, the TXV was colder on the bottom than the side so I guess it is working but just suffering from lack of refrigerant.
So, it appears I have a leak somewhere and likely an incompetent or untruthful mechanic.
Pato911 05-24-2014 11:26 AM
Any recommendations while I have the gauge set or should I get the system evacuated in preparation for disassembly?
Bob Kontak 05-24-2014 03:36 PM
Open it up and get on with it. You got "four" ounces in there and you have lost 25 or more.
Bob Kontak 05-24-2014 04:01 PM
Oh, he knows how to check a system for leaks. This is pure lazy or his boss is beating on him to churn cars and he can't afford to take the time.
One of the beauties of DIY work. Low cost, good quality if you are diligent but you will not make shop rate.
tirwin 05-24-2014 05:14 PM
I have taken my car to one shop for a mechanical repairs (excluding tires/alignment and body shop). It will never go back there again. Outright dishonesty. I'm doing everything on my car including the A/C. I would go broke doing this for a living but I prefer knowing the job is done right. I have all the parts from Griffiths. I have 2 more small projects in the queue before I get started.
cabmandone 05-25-2014 05:48 AM
I have a suggestion, throw some refrigerant in it and drive the car. When you have it gassed up, look for refrigerant oil that is a telltale sign of a leak or a proximity of where the leak is. Rather than removing every part and replacing, find the leak, fix it and move on. If you can't find oil, go get a R134 leak detector and sniff out the problem. You could replace seals and still not fix the leak because it could be on the coil ends of the evaporator or condensers at the front and rear.
