Non-working AC thread #3141592
Yep, I tried searching....
I have an '87 Carrera with a, as far as I know, stock AC system. The PO converted to R134 (drier change unknown). A month ago, I got the system recharged and had them add dye. The AC vent would put out ~58F air at ~80F ambient (Houston). A couple weeks later, I noticed it no longer put out cool air and as of today the vent temp is essentially ambient. What I have checked: 1) I took it back to the shop and they said pressure was good and found no leaks with the UV light. 2) Compressor clutch is engaging, front condenser fan is running, evaporator fan runs in all three speeds and temp knob is at max. 3) I do not see bubbles in the drier sight glass (but also cannot tell if there is flow). See photo two. 4) The inlet side of the rear deck condenser is very hot and the outlet is slightly above ambient. 5) Visual inspection of the TXV revealed nothing but I did notice that the connection to the silver relay/ switch on the passenger side of the smugglers box was loose (top of photo one). I made sure it was fully inserted but it had no apparent effect. I suspect a bad TXV or plugged component but is there any other potential culprits or checks I can do (without a gauge set)? Recommendations? Thanks in advance. http://forums.pelicanparts.com/uploa...1400716225.jpg http://forums.pelicanparts.com/uploa...1400716243.jpg |
Sounds like the dye may have caused a blockage. If the condenser is really hot and the line is at ambient temp then that is where the blockage could be. Seems you have a no flow problem
I would ask if they checked both high side and low side pressure, and what were the readings..
And pic #2 looks like there is no flow. |
What is the solution for no flow blockage? Can it be flushed in place or do I need to pull the system apart? I will go back by the shop on Friday and talk to them about pressures and flushing, if possible.
Pfffft. Come on. Dye caused a blockage? If there is blockage, a look inside the sight glass indicates that operation caused a blockage and the expansion valve would be the place I would start. How about a leak? Is that possible? |
Your option would be to take the P-car to a A/C shop and have them put gauges on the system with the compressor running to see if it is pumping refrigerant. Then you will know for sure if it's blocked. One other option would be - it's completely out of refrigerant.
That said. Here is my suggestion. It worked for a little bit, right? That means the system is kind of functioning. Is there a lot of refrigerant in your system? Press on the schrader valves to check. If so, blockage. If not, leak. Get a new dryer and an expansion valve. Regardless of leak, your system needs revitalizing. Use and air compressor, mineral spirits and a friend and clean the living snot out of your system. Dump the oil out of the compressor and replace with PAG. Search on how many ounces or call Griffith's Tech and Charlie will tell you. Put two ounces in the other components - mainly the evaporator and the dryer. Suck down a vacuum, even with the el-cheap-o Harbor freight $15 unit. The $50 gauges from the freight would help here. Recharge with maybe 5 oz less than what the R12 would be and check pressure. Add a wee bit of R-134 if high side is low based on graphs. Low side will be around 45-50. Is this optimal. Nah. Compared to what you have it kicks ass. Alternatively, spend $750 for a refresh of your system by a shop. |
This might not have anything to do with your problem, but it looks like the dryer is crushed at the top (near the fitting) - is that the case?
Also you mentioned in your first post that the a/c shop said the pressures were good, if that is correct (if the techs know WTF they are doing), I don't see how you could have any kind of obstruction in the system . . . |
That is wrong. The more I look at it the more it looks like the whole tube took a big honkin' whack. Bottom is whopper-jawed as well. Not dented, just crooked. |
I don't think it's your TXV. The TXV meters flow of refrigerant into the evaporator coil. If there was a problem, it would show up in the pressure readings. If the TXV sensing bulb was bad, the valve would "search" meaning it would open and close changing pressures and you'd never get a good pressure reading. An old rule of thumb is that you should have condensation on the suction line.
2. If your clutch is engaging, the compressor should be pumping and there should be sufficient (not full or properly charged just sufficient) refrigerant because most systems use a pressure switch to determine there is refrigerant and that the clutch should engage. 3. You should be able to put a screwdriver to the line and the end to your ear and hear a pulsation from the flow 4. Inlet of the condenser should be hot outlet cooler. The condenser is removing the heat extracted by the refrigerant then cooling and going back for more. 5. RE txv, see my other comment. I don't do car AC but did AC for a living. Principles don't change just pressures and temperatures. |
That drier looks original, and that isn't good. Plus it looks damaged.
As Bob mentioned, the first thing I would do is check for pressure at the Schrader valve. By the looks of it the R134 "conversion" consisted of putting new fittings on the compressor and recharging with R134. If there is no pressure in the system (check first!) remove one of the A/C lines and see if the O-rings are the original black ones, or if they have been replaced by the green nitrile O-rings. If they are black, they may be a major source of your leakage. If your compressor works, you have a decent chance of getting a functional system by replacing all of the O-rings, swapping the receiver-drier, and the expansion valve. All those parts can be had for about $70. Pickup a Harbor Freight vacuum pump & gauge set (about $150 for both -- or borrow them), and you are in business for around $250 (including refrigerant and oil). Clean the major components as Bob described, swap the O-rings, install new expansion valve, install new receiver drier (do this last), then pull a vacuum and see if it holds. If so, charge it up and Bob's your uncle. Not the perfect fix (probably marginal for Texas or Arizona) and it will probably leak some over the course of the year. But I get vent temps in the low 40s doing this, and it is good enough (especially on a Cab!) Good luck. |
1) The system was not properly converted to R134a. Besides the sexy shaped drier, you have junk in the sight glass.
2) Unless you want to revisit the AC system monthly, or weekly, you will need as a minimum: A) Liquid flush hoses, evaporator (with TEV off), condensers, tear down the compressor and inspect it and reseal or replace. You will have to drop the lines that rise above the gravity line; might want to think about just replacing them all a good barrier set while you are at it cause you will be recharging sooner or later because of the stock lines. B) You can either borrow or buy an AC flush canister and a gallon of AC flush (avoid other chemicals) or buy 4 cans of Interdyanmics CA-1 AC flush http://forums.pelicanparts.com/uploa...1400758693.jpg C) You will need a low-high pressure switch. D) You will need to have a professional evac, charge and test, unless you want to spend your evenings reading the threads here or your weekends "learning" the hard way. 3) When all is said and done, you are not going to be happy with a stock system in your climate. So stop and think where you are headed. And, Read The Mr. Ice Project |
Thus begins the slide down the slippery slope of A/C threads.
Cue wwest to discuss trinary pressure switches and condenser fans or whatever. Not that kuehl is wrong by any means. But once you go the way of barrier hoses, you are in full-fledged "while you are in there" mode. As with everything DIY, you have to make your own calculations about money-labor-time-value. It absolutely can be done in a long Saturday, with a minimal investment (under $300) -- and you can get good results. But they are not guaranteed, and may require seasonal maintenance. You are gambling a small amount of money and some time that there are no major component with serious leaks or damage. If you want a guaranteed excellent result as kuehl describes, expect to pay 8-10 times that amount. There is some middle ground between the two approaches (ie, replacing a weak compressor or leaking evaporator), but once you start changing major components & hoses, you may as well go the full monty. |
I am happy with my $300 results -- and have working A/C. Yes, that is a sample of one. But I doubt I experienced an A/C miracle. |
That is some nasty looking schmeg in that filter drier.
Pull the gas, change the drier, leak check and pull a good vacuum. a good system flush will probably be in order while your in there. That would be bare minimum.... If you are looking to end refrigerant emissions (as you should) replace the hoses. |
You also need to really LOOK at the evaporator. It is obvious your car is actually driven in the rain as is my car. I bought my car long ago but it was used as a daily driver by the previous owner.
When I did my AC conversion to the dual Kuehl system I planned to replace my evaporator anyway. This is the bottom of my old evaporator. http://forums.pelicanparts.com/uploa...1400764093.jpg No doubt that was part of my problem. The AC worked before but was just cool, not cold. Now it works great. I added the two rear fender condensers, changed the hoses, receiver-dryer & evaporator. It was expensive but my wife will ride with me in HOT climates and I can keep myself cool. |
Driving down the present Road
Typical DIY, first-timer, average flush times: Time required to remove and reinstall (R&R all hoses: 6-8 Time required to R&R evaporator: 3-5 Time required to R&R 2 stock condensers: 3 Other Compressor R&R for - Inspection & Reseal: 3 Drier R&R - ˝ Source & Procure ‘cheap’ vacuum pump, gauge set - 1 Source & Procure R134a cans - ˝ Source & Procure Electronic Sniffer - ˝ Source & Procure Drier, O-rings, R134a oil - ˝ Figure out how to Evac, Charge and Test - 1 to 3 Proper Evac, Charge and Test - 4 to 5 Leak Check (electronic) - ˝ Read Forums and Trouble Shoot - 6+++++ ======================================== 30-40 Hours End Result The vehicle will perform no better than the day it rolled off the factory floor, and in a Houston climate you will not be happy. And, the more you use a stock type system at those higher Houston ambient temps the quicker the refrigerant will leak out.... hence you will be spending your time back here. |
I was traveling down the same A/C road of what do I do. Sometime back I converted my R12 system to R134a on my '87 by doing what COLB suggested with somewhat OK results. However, the longest period of charge I could keep in my system with the old hoses was about 3 months. I had no leaks anywhere determined by leak test except through the old hoses. So, after about the 4th recharge I elected to redo my system by replacing the TEV, new OEM compressor, new drier and last but not least, new hoses. In addition, I pulled the evap for a thorough flush along with flushing both front and rear condenser. For flushing, I used the product that kuehl mentioned in his post above. It works fantastic. After pulling my old hoses I inspected each of them and they were really sad as they had surface cracks all over, and what I assumed was weather checking on just about every hose. Would one expect less after 27 years living under a car? Pulling the hoses is not that big of a job but, just dirty and tedious. Since I live in an area that has a short and mild summer I elected not to install extra fans, new evap etc. as I don't need the A/C that often. Send a PM to kuehl, he definitely knows A/C and he will put you on the right path to having the best working A/C system.
| All times are GMT -8. The time now is 11:59 AM. |
