-   -   Charcoal filter issue, Euro - vs - US. HELP! (http://forums.pelicanparts.com/porsche-911-technical-forum/812565-charcoal-filter-issue-euro-vs-us-help.html)
GeorgeK 05-22-2014 11:42 AM
As I am "cleaning up" the federalisation work dating back to 1984, I have hit a weird setup with the gas and oïl vapors.
There is a long tube leading from the front left inner wing (and then to the small clear plastic canister by the fuel filler tube) back Under the car, into the engine compartment, and into a canister of sorts, that is just in front of the air filter box. The canister just lays there, not attached to anything. into the same canister goes a tube from the oil reservoir by the filler, and another, smaller air tube from an air tube by the inlet tracts.
I gather that he canister is the charcoal filter.
So, could anyone who has an euro 3.2, or knows them enlighten me about the position and connections into that canister? See attached (bad pictures):
http://forums.pelicanparts.com/uploa...1400787611.jpg
http://forums.pelicanparts.com/uploa...1400787628.jpg
twistoffat 05-22-2014 09:01 PM
I think this thread will answer all your questions :)
http://forums.pelicanparts.com/porsche-911-technical-forum/636397-charcoal-canister-delete.html
GeorgeK 05-22-2014 09:42 PM
Thank you twist. Makes sense.
Does anyone have a picture of the charcoal canister in its correct position?
GeorgeK 05-27-2014 12:21 AM
Pretty please?
I would need to know which tubes go through the inner fender to the canister since my car has been "modified" in that area.
twistoffat 05-27-2014 03:18 AM
heres a Pet diagram of the part. I´ve an 87 I´ll see if I can get a picture later for you to show the hoses.
http://forums.pelicanparts.com/uploa...1401189509.jpg
twistoffat 05-28-2014 06:20 AM
Sorry for the crappy pics George but it at least shows where the cables run
http://forums.pelicanparts.com/uploa...1401286575.jpg
http://forums.pelicanparts.com/uploa...1401286674.jpg
http://forums.pelicanparts.com/uploa...1401286717.jpg
http://forums.pelicanparts.com/uploa...1401286762.jpg
http://forums.pelicanparts.com/uploa...1401286813.jpg
GeorgeK 05-28-2014 06:56 AM
Yes!
Thank you. Makes sense. I can now find a bracket and replace the canister that is laying in front ot the airbox.
