Charcoal filter issue, Euro - vs - US. HELP!
As I am "cleaning up" the federalisation work dating back to 1984, I have hit a weird setup with the gas and oïl vapors.
There is a long tube leading from the front left inner wing (and then to the small clear plastic canister by the fuel filler tube) back Under the car, into the engine compartment, and into a canister of sorts, that is just in front of the air filter box. The canister just lays there, not attached to anything. into the same canister goes a tube from the oil reservoir by the filler, and another, smaller air tube from an air tube by the inlet tracts.
I gather that he canister is the charcoal filter.
So, could anyone who has an euro 3.2, or knows them enlighten me about the position and connections into that canister? See attached (bad pictures):
Old 05-22-2014, 12:42 PM
twistoffat's Avatar
I think this thread will answer all your questions
Charcoal Canister Delete
Old 05-22-2014, 10:01 PM
Thank you twist. Makes sense.
Does anyone have a picture of the charcoal canister in its correct position?
Old 05-22-2014, 10:42 PM
Pretty please?
I would need to know which tubes go through the inner fender to the canister since my car has been "modified" in that area.
Old 05-27-2014, 01:21 AM
twistoffat's Avatar
heres a Pet diagram of the part. I´ve an 87 I´ll see if I can get a picture later for you to show the hoses.
Old 05-27-2014, 04:18 AM
twistoffat's Avatar
Sorry for the crappy pics George but it at least shows where the cables run
Old 05-28-2014, 07:20 AM
Yes!
Thank you. Makes sense. I can now find a bracket and replace the canister that is laying in front ot the airbox.
Old 05-28-2014, 07:56 AM
