| Registered |
				Cat Bypass 78 SC suggestions/advice
			I just acquired a 78 SC.  35,000 miles and it appears to be equipped just as it came from the factory.  I figure the CAT is plugged/useless and will impact performance.  I see no reason to keep it, so the plan is to take it off. However, I may want to upgrade my muffler at some point with something that sounds a bit deeper and throatier. Perhaps a winter project along with upgrading the chain tensioners while the muffler is off. But, in the meantime, I want to put on a CAT Bypass. I see a number of CAT Bypass options -- both OEM type and "performance" type. Big price difference. So --- can I put on the OEM CAT Bypass and later put on a performance muffler or will the OEM CAT Bypass restrict me to an OEM muffler?
				__________________ Brad Inventor of SNAPGAP - The Valve Adjustment Solution Patented in U.S. and Europe. Go to SNAPGAP.US or PM me. https://www.pelicanparts.com/More_Info/SNPVAK11146.htm?pn=SNP-VAK11146 | ||
|  06-05-2014, 11:42 AM |
| Registered |
			I would look up RarlyL8.com (fellow pelican) he makes great products. I dont see a problem in installing a bypass pipe first and muffler later.
				__________________ Jesper Carrera 3.0 1975 930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer www.stauningwhisky.dk | ||
|  06-05-2014, 11:50 AM |
| Registered Join Date: Apr 2005 Location: outta here
			My guess is that you won't notice any difference, except for a little more noise.  I'd imagine all of these are designed to be used with stock heat exchangers and a stock muffler, so the attachment points will be suited to those.  Having said that, most single inlet mufflers have the same inlet mounting dimensions as the stock muffler, so they can be installed on otherwise-stock vehicles. SO, my guess would be the mounting details will all be the same. I'd pick the one you think might be the best quality, or the least damaging to performance.  I'd also make sure you order all of the gaskets you need and a plug for the O2 sensor bung that is in most of these. JR | ||
|  06-05-2014, 11:54 AM |
| Registered |
			I've got a euro pre muffler I just took off my 79SC  when I put SSI's on. If it's anything you'd be interested in let me know. It's slightly louder than the CAT that was on it but not by much.   Any single inlet muffler will work with a bypass pipe.
				__________________ Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey | ||
|  06-05-2014, 12:11 PM |
| Registered |
			I just gutted mine out with a piece of rebar. Just a little louder
|  06-05-2014, 12:29 PM |
| Registered |
			I like that idea -- gutting it -- for the short term.  Thanks.
|  06-05-2014, 12:55 PM |
| Registered Join Date: Nov 2001 Location: Santa Maria, CA
				 | Quote:
 As for the chain tensioner "upgrade", it's not. It's a major wallet emptying when a hundred bucks and a couple of hours of your time spent rebuilding your old tensioners will do the job just as well. You may not know it, but the pressure fed variety fail, too. The Cap'n | ||
|  06-05-2014, 12:56 PM |
| Registered Join Date: Oct 2008 Location: Denver, CO
			agreed with the cap'n -- my cat is @ 160k and 25 years old and still works like new.  Unless you have a clear indication that the cat's plugged, I really doubt you'll obtain a perceptible performance increase adding a bypass and you'd be better off leaving your exhaust system as-is until you can perform a significant upgrade -- many folks look at a ssi header / exhaust system as providing a noticeable performance (and sound) improvement.  If your stock exhaust is in good shape, it could well be of interest to somebody trying to smog their sc and could help finance a significant portion of the ssi/dual in muffler setup
|  06-05-2014, 01:10 PM |
| Registered Join Date: Jul 2013 Location: Plano, TX
			fabspeed and M&K both make well-known pre-mufflers (cat replacements) and costs are reasonable - $400 or so. a pre-muffler will hook up in the same position as the cat and attach to any muffler in the stock position, leaving your options wide open. rarlyl8.com seems to sell M&K mufflers, but some of his products could be proprietary. i'd like to see someone make a single or dual resonator option for a muffler besides fabspeed. no complaints on their piece, but it would be nice to have options without resorting to dynomax/magnaflow products and a muffler shop. i'd also like to see another vendor producing a muffler bypass pipe.
				__________________ '04 GT3 '97 C4S '90 C2 '86 951 | ||
|  06-05-2014, 01:19 PM |
			I'd like to see somebody dyno test these things, to see if any of them actually do any good.  "Pretty" does not always equal "well designed" or "a measureable improvement: JR | ||
|  06-05-2014, 01:36 PM |
| Registered Join Date: May 2008
			Brad; be sure to check your state's smog laws, in CA removing the cat would be illegal.
				__________________ Keep the Shiny Side UP! Pete Z. | ||
|  06-05-2014, 03:53 PM |
