915 shifter- wevo upgrades- what else while I'm in there
Hey everyone.
so i just ordered a new wevo 915 shifter, psj shift joints and transmission mounts.
before i start digging into this is there anything else i should order to replace while i am in there? like any bushings, trans fluid...ect?
thansk for the help!
Levi
Old 05-30-2014, 07:43 AM
oh snap's Avatar
if you are looking for things to do you may also want to have a look at the clutch cable, helper spring assembly and pedal cluster to make sure its all adjusted and working properly. Its not quite "in there" but its worth mentioning because it can be the cause of grinding or balky gears.
1985 Iris Blue M491 911 Coupe
Old 05-30-2014, 08:27 AM
Flat Six
Flat Six's Avatar
Don't forget ball cup bushing and shifter rod bushing. If working on clutch cable, might as well take a look at the throttle linkage and ground strap.
Dale
1985 Carrera 3.2 -- SOLD
2026 Jaguar F-Pace / 2025 Ford Bronco Sport
Old 05-30-2014, 09:55 AM
RETIRED
Joe Bob's Avatar
Interior support plate for the intermediate bearings. You have to open up the box....
2012 ML350 3.0 Turbo Diesel
Old 05-30-2014, 01:02 PM
Air Cooled
Craig_D's Avatar
You're gonna LOVE this update, Levi! I agree with the above comments as well, although I still need to do my pedal cluster, but it's next on my list.
Originally Posted by saxen View Post
Hey everyone.
Levi
'78 911 SC "Blackjack" & '76 914/4 2.0L "The Brat"
'99 Honda VFR800Fi, '98 Honda SuperHawk
'88 Honda Hawk GT, '77 Honda CB750K Cafe
'69 Honda CL350
Old 05-30-2014, 03:38 PM
thanks guys!
Craig- I need to re-build mine as well- hit me up when you plan on doing yours- lets kill two birds with one stone= i'll pick up some nice craft brews on the way over
thanks for the help guys- just a frew short questions-
for shifter rod bushing should I use the brass kit part number PEL-BUSH-BR found at the bottom of this page?
Porsche 911 (1974-1989) - Shift Linkage - Page 2
and this part Porsche 911 (1974-1989) - Shift Linkage - Page 3
Part Number: 911-424-139-00-M260
Old 06-01-2014, 09:41 PM
Flat Six
Flat Six's Avatar
thanks guys!
for shifter rod bushing should I sue the brass kit part number PEL-BUSH-BR found at the bottom of this page?
For the ball cup bushing use:
Part #: 911-424-139-00-M260
And for the shift rod bushing use:
Part #: 914-424-224-00-M260
Remember to grease the inside of the ball cup bushing (I use standard moly lube). Also, the shift rod bushing can be a b***h to replace. Place the new bushing in a cup of hot water (not boiling; about the same temperature as a hot cup of coffee) for 60-90 seconds. Makes the bushing temporarily more flexible & pops right into the bracket with a little pressure from your thumbs. Easy peasy & makes a world of difference.
Dale
Old 06-02-2014, 07:46 AM
your the man! thansk Flat 6!
Old 06-02-2014, 08:11 AM
Just an FYI, the ball cup and shift rod bushings are included in the WEVO shifter kit.
As others have said, I recommend replacing the clutch cable, omega spring, rebuilding the pedal cluster, and changing your gearbox fluid.
Old 06-02-2014, 10:12 AM
Flat Six
Flat Six's Avatar
Thx Will; didn't know that . . .
Dale
Old 06-02-2014, 04:22 PM
