MSD says they only make belt drive systems for V8 engines
I figured since it has 2 MSD units on it, that maybe MSD made a belt driven distributor in the past. But the tech I spoke to one the phone today said they only make them for V8 engines. Looks like front mounts for GM small and big block motors.
Thanks for your hard work looking! I did the same. |
Not a hi jack at all, love the input! Thanks |
Just thinking it wouldn't be impossible to re-work the second dizzy you have, such that you could eliminate the belt and adapt it directly to the cam.
Did a quick google on timing belts and found a few places that sells belts and pulleys, for example: Robot MarketPlace - Timing Belts
| All times are GMT -8. The time now is 05:48 PM. |
