-   -   3.2 intake rib/support delete? (http://forums.pelicanparts.com/porsche-911-technical-forum/814119-3-2-intake-rib-support-delete.html)
bkreigsr 06-02-2014 04:25 AM
These ribs are starting to annoy me.
Anyone ever grind them off?
Do the serve any other purpose other than support the blower and act as a heat sink for the intake air?
Bill K
http://forums.pelicanparts.com/uploa...1401711820.jpg
Rob T. 06-02-2014 04:40 AM
I removed the base for the blower.
Never missed it....
http://forums.pelicanparts.com/uploa...1401712796.jpg
bkreigsr 06-02-2014 04:45 AM
Now THAT's what I'm talking about.
Nice motor Rob. What year?
Bill K
Rob T. 06-02-2014 04:49 AM
Thank you Bill.
Itīs a 3,2 ROW engine from 86.
While you are in you could also remove the scars from
casting between the intakes.
911pcars 06-02-2014 08:55 AM
Here's my intake manifold after several hours of prep and finishing - soon to be installed.
http://forums.pelicanparts.com/uploa...1401728059.jpg
Sherwood
Rob T. 06-02-2014 10:00 AM
Looks familiar... great :)
Have you already choosen a color?
ClickClickBoom 06-02-2014 10:14 AM
Bill K
They are starting to annoy me too! The red lines are making me, well.......see red......
It's never too early for Jack and coke!
ClickClickBoom 06-02-2014 10:16 AM
On another note, has anyone done a before dyno and extrude hone after dyno run series?
turbobrat930 06-02-2014 10:27 AM
Here is a 3.2L intake in Perma chrome (ceramic coating)... casting marks removed... but I kept the bracket you are inquiring about to mount my coils to....
[IMG]https://farm3.staticflickr.com/2902/...6858c110_b.jpg[/IMG]
turbobrat930 06-02-2014 10:35 AM
No, but I will tell you this... I have a before and after compairson of my intake. The thing to remember about ExtrudeHone process, is that you are not taking large amounts of material out. As such, the flow will only increase a little bit (no huge gains there). IIRC, the increase was only about 50CFM more over stock...
The real benefit comes from having the runners balanced to each other. Before ExtrudeHone process, they were 50 to 70CFM difference between all 6 runners (IIRC), and after the process, it was less than 5 CFM....
For my engine, I wanted it to be as balanced as possible, as much HP as I am looking to get out of it.....
Brad
911pcars 06-02-2014 10:45 AM
After surface prep, the manifold was polished.....
http://forums.pelicanparts.com/uploa...1401734349.jpg
....followed by glass bead blasting approximating an RSR Fuchs finish:
http://forums.pelicanparts.com/uploa...1401734610.jpg
....then protected by a clear satin ceramic finish as seen in post #5.
Sherwood
911pcars 06-02-2014 07:23 PM
FWIW, I recorded some in-process deletion pics.
http://forums.pelicanparts.com/uploa...1401765183.jpg
I wonder if there's anything here I need? Oh well.
http://forums.pelicanparts.com/uploa...1401765198.jpg
Now it's a "lightweight" intake manifold. This is about 2/3 of the debris:
http://forums.pelicanparts.com/uploa...1401765212.jpg
Sherwood
Ferrino 02-11-2015 04:50 PM
What were your plans for the support for that long tube that leads to the venturi gizmo, if you chop the bracket? Just leave the tube dangling? My understanding is that the tube can be eliminated entirely if you don't need the brake booster. I'm guessing you use a brake booster though...
Bill K
bkreigsr 02-11-2015 05:03 PM
See post #2. The "y" junction is available at Home Depot or Lowe's.
gliding_serpent 02-11-2015 05:13 PM
You guys are all sick, and I like it.
bkreigsr 02-11-2015 06:15 PM
Originally Posted by gliding_serpent (Post 8482910)
You guys are all sick........
I have no idea what you're talking about......;)
http://forums.pelicanparts.com/uploa...1423710921.jpg
Ferrino 02-11-2015 10:35 PM
Which "y" junction? Isn't the arrangement in post #2 just the later venturi setup which doesn't have the same support arm?
