cycling has-been
bkreigsr's Avatar
3.2 intake rib/support delete?
These ribs are starting to annoy me.
Anyone ever grind them off?
Do the serve any other purpose other than support the blower and act as a heat sink for the intake air?
Bill K
Old 06-02-2014, 04:25 AM
Rob T.'s Avatar
I removed the base for the blower.
Never missed it....
Old 06-02-2014, 04:40 AM
cycling has-been
bkreigsr's Avatar
Now THAT's what I'm talking about.
Nice motor Rob. What year?
Bill K
Old 06-02-2014, 04:45 AM
Rob T.'s Avatar
Thank you Bill.
Itīs a 3,2 ROW engine from 86.
While you are in you could also remove the scars from
casting between the intakes.
Old 06-02-2014, 04:49 AM
Here's my intake manifold after several hours of prep and finishing - soon to be installed.
Sherwood
Old 06-02-2014, 08:55 AM
Rob T.'s Avatar
Looks familiar... great
Have you already choosen a color?
Old 06-02-2014, 10:00 AM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
Bill K
They are starting to annoy me too! The red lines are making me, well.......see red......
It's never too early for Jack and coke!
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 06-02-2014, 10:14 AM
On another note, has anyone done a before dyno and extrude hone after dyno run series?
Old 06-02-2014, 10:16 AM
E-85 sippin drunk
turbobrat930's Avatar
Here is a 3.2L intake in Perma chrome (ceramic coating)... casting marks removed... but I kept the bracket you are inquiring about to mount my coils to....
[IMG][/IMG]
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk
Old 06-02-2014, 10:27 AM
E-85 sippin drunk
No, but I will tell you this... I have a before and after compairson of my intake. The thing to remember about ExtrudeHone process, is that you are not taking large amounts of material out. As such, the flow will only increase a little bit (no huge gains there). IIRC, the increase was only about 50CFM more over stock...
The real benefit comes from having the runners balanced to each other. Before ExtrudeHone process, they were 50 to 70CFM difference between all 6 runners (IIRC), and after the process, it was less than 5 CFM....
For my engine, I wanted it to be as balanced as possible, as much HP as I am looking to get out of it.....
Brad
Old 06-02-2014, 10:35 AM
After surface prep, the manifold was polished.....
....followed by glass bead blasting approximating an RSR Fuchs finish:
....then protected by a clear satin ceramic finish as seen in post #5.
Sherwood
Old 06-02-2014, 10:45 AM
FWIW, I recorded some in-process deletion pics.
I wonder if there's anything here I need? Oh well.
Now it's a "lightweight" intake manifold. This is about 2/3 of the debris:
Sherwood
Old 06-02-2014, 07:23 PM
Ferrino's Avatar
What were your plans for the support for that long tube that leads to the venturi gizmo, if you chop the bracket? Just leave the tube dangling? My understanding is that the tube can be eliminated entirely if you don't need the brake booster. I'm guessing you use a brake booster though...
Bill K
Old 02-11-2015, 04:50 PM
cycling has-been
bkreigsr's Avatar
See post #2. The "y" junction is available at Home Depot or Lowe's.
Old 02-11-2015, 05:03 PM
gliding_serpent's Avatar
You guys are all sick, and I like it.
1997 BMW M3 (race car) with S54 engine swap "The Rocket"
1984 Porsche 911 3.4 Carrera
1973 BMW 2002Tii
2016 Ford Focus RS
Old 02-11-2015, 05:13 PM
cycling has-been
bkreigsr's Avatar
Originally Posted by gliding_serpent View Post
You guys are all sick........
I have no idea what you're talking about......
Old 02-11-2015, 06:15 PM
Ferrino's Avatar
Which "y" junction? Isn't the arrangement in post #2 just the later venturi setup which doesn't have the same support arm?
Old 02-11-2015, 10:35 PM
