kodioneill's Avatar
strange breather oil passage issue
Chasing an oil leak from the top of engine I replace all the common things but when I replaced the crankcase breather hose (on top) I blew through the hose just to see if it was clear I got a spurt of oil and air flowing out of the oil cooler hole on the top right. As I blow harder with air pressure the air keeps flowing out the oil cooler supply hole as hard as the air going in????? Doesn't seem right to me I also have low oil pressure at idle any ideas??
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 06-02-2014, 08:56 AM
What oil cooler hose connection is open on the top right? I can,t picture one above the tank or engine.
1980 911 SC 3.6 coupe sold
1995 993 coupe
1966 Mustang Shelby clone
1964 Corvair Spyder Turbo gone
2012 Boss 302
Old 06-02-2014, 09:00 AM
kodioneill's Avatar
I have the oil cooler off the engine and the top right hole is where the air is coming out. This would indicate to to me the oil system is not closed.
1982 chiffon 911sc
Old 06-02-2014, 09:09 AM
My somewhat educated guess. If your crankcase is drained of oil, you are most likely blowing air through the pressure side of the oil pump gears. You mentioned low pressure,
perhaps the pump has worn beyond tolerance.
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 06-02-2014, 09:25 AM
E Sully's Avatar
If you pressurize the crankcase through the vent hose, I would think the cam spray bars would be path for the air to push back towards the cooler. The system is open because you have the cooler off.
Ed
1973.5 T
Old 06-02-2014, 09:27 AM
