davis911s's Avatar
Question No Low Beams????
Ok I am trying to help a new 911 owner fix some bugs in his car
It is a 80SC
The problem right now is he has high beam ONLY. When you use the dimmer switch NOTHING happens, the lights just stay on high beam.
I took the switch at the steering column out (not disconnected just out to look at) and everything looks fine. Is the something I should be looing at in particular?
Here is the part I am talking about.
http://www.pelicanparts.com/catalog/shopcart/911M/por_911M_electr_main.htm
Thanks everyone.
Would he be better off just buying a new part or can I save this one possibly?
Shawn
Shawn
77 Targa with 2.7
My never-ending work in progress that has been off the road since Mar 2004
Old 09-21-2002, 01:32 PM
bb bb is offline
I had the same problem, replaced switch on column with a used one and problem fixed.
Old 09-21-2002, 07:02 PM
nostatic's Avatar
I had pretty much the same problem...high beams only, but in addition my guage lights wouldn't dim. I replaced both the headlight switch and the turn signal stalk switch with new ones. Problem solved. For a long term fix, have him add relays for the headlights.
headlight relay install
Old 09-21-2002, 07:20 PM
Cool
Shawn...bb and nostatic know the headlite game/no question..might as well do headlite relays while your in there..why waste a new part without relays..kinda like, no low beams then post implant ..............Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 09-21-2002, 07:55 PM
Unhappy
Heres a kicker.....
No left low beam......both high beams ok.
New bulbs(H4)
Sucro's relay kit installed
new turn sig switch
now....all blinkers ok(after cleaning and adj. bulb contacts)
then new headlite switch...
only happens w/lights on-
right side blinkers on, no blinking
left sides ok
both brake lites on, no brake lite function(on/off w.brake switch)
put back old headlite switch-same prob.
checked all sig/lite grounds-all ok(now!)
ChadC
71 911S Targa
Old 09-21-2002, 08:41 PM
woops.....sorry to borrow your post, Shawn! Experiencing the same stuff!
ChadC.
71 911S Targa
Old 09-21-2002, 08:47 PM
