1980 RoW 911SC the odometer gear, how many tooth i need.
The car is 100km from me, and i cant check it., and I have family coming from Chicago to Poland on sunday.
Today I have to order odometer gear (odometer does not work) in my 911
speedometer is in miles.
The car is a RoW 911 from 1980,
do i need Porsche -US 911 76-89 20 x 30 Odometer Gear
please confirm asap
Old 06-03-2014, 01:42 AM
Odometer gear replacement........
Ernest,
Sent you a PM who to contact for your odometer gear.
Tony
Old 06-03-2014, 07:17 AM
TheSt|G's Avatar
There is a chart that our host has in the odometer gear section of the parts catalog.
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs
2005 E46 M3- Daily Beater - 3350lbs
Old 06-03-2014, 08:20 AM
This one: Porsche Odometer Gear Reference
It does not list a 1980 Rest Of World 911 but that gear is the only mile version in your vintage so if it does not fit (20 and 30 teeth) you are screwed anyway.
I bet they would take it back if it is not the right one.
Rick
88 Cab
Old 06-03-2014, 08:46 AM
Josh D's Avatar
I have an '80 RoW and I just replaced mine. I can't remember what the tooth count was though! It is not the same as the US. I bought a US one and it was not correct, so I counted the gear teeth and bought the correct one.
'80 RoW 911 SC non-sunroof coupe in Guards Red
It's not a Carrera.... It's a Super Carrera!
Old 06-03-2014, 10:57 AM
Plastic gear color......
Josh,
Do you remember the color of the plastic gear? The OP needs to order it right away and have it shipped to IL before Saturday (June 7) to make it to Europe.
Tony
Old 06-03-2014, 11:04 AM
Josh D's Avatar
Originally Posted by boyt911sc View Post
Josh,
Tony
Let me go to the website to see if it sparks my memory.
Old 06-03-2014, 11:12 AM
Josh D's Avatar
There were two options:
20/32 US
20/22 Euro
I initially tried 20/32 and it did not work. So it must be 20/22. I do remember the inner gear being much smaller than the US gear, so the 22 tooth count sounds about right. My speedo does have 0-150 mph face plate and it is accurate.
Hope this helps!
Old 06-03-2014, 11:22 AM
pete3799's Avatar
Porsche 20X22 tooth gear is all it says on my receipt (2/11/2010). No part number listed.
This was what I put in my 79 Euro. Purchased from Odometer Gears LTD. before Pelican had them available. I think it's the same company that Pelican gets them from.
Pete
79 911SC RoW
Old 06-03-2014, 01:09 PM
esonefour's Avatar
Good luck on the rebuild.
Mine stripped last year, and it was so tricky to count the teeth or lack of.
VDO needed to switch cog suppliers.
Old 06-03-2014, 03:39 PM
