Flyin' blind
new strut inserts… need alignment?
Just finishing replacing 100K mile Boge inserts with Koni sports. I also removed the old rubber camber bushing and replaced it with the included rubber inserts. The camber plate was not touched.
Do I need an alignment? Thanks!
Thom 89 Coupe |
I expect the camber bushing you mentioned is actually the bump stop on the shock shaft. camber,caster and toe should not have changed because the insert was changed you didn,t move the top mount so I think you are correct no alignment needed.
1980 911 SC 3.6 coupe sold 1995 993 coupe 1966 Mustang Shelby clone 1964 Corvair Spyder Turbo gone 2012 Boss 302 |
If you replaced the old rubber in the camber plate, all the new rubber will do is prevent the strut from moving as much. So, as long as the camber plate is in the same spot, you are fine alignment-wise.
Flyin' blind
Thanks! That's what I thought...
Thom 89 Coupe |
