-   -   A/F meter in dash clock position (http://forums.pelicanparts.com/porsche-911-technical-forum/814920-f-meter-dash-clock-position.html)
Rleog 06-06-2014 03:12 PM
Have any of you installed a 2 1/16" diameter A/F meter in the clock space? If so, what did you use to adapt the smaller gauge to the dash space?
Tippy 06-06-2014 03:14 PM
The clock lens. I whittled a hole in a busted clock, painted lens black, and mounted WBO2 to it.
Uwon 06-06-2014 06:59 PM
Look at this as a start.
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/792243-plx-wideband.html
It will wet your appetite.
Cheers,
Johan
Rleog 06-06-2014 07:08 PM
OldSpool87 06-06-2014 07:21 PM
Our host sells a plastic plug for the gauge (delete plug). I got one and hole sawed approximate diameter. Looks pretty good.
dicklague 06-06-2014 10:03 PM
I have used the plastic clock plug that Pelican sells. It is a very nice machined piece.
I just finished the install using the Daytona-Sensors WEGO IV unit. This one is all self contained and you can download data from the front panel USB connector.
I have also built in a digital readout above it that is a clock, volt meter, and temperature gauge. I will post photos tomorrow.
Tippy 06-06-2014 10:56 PM
If I'd known Pelican had the plug, I wouldn't have mutilated a clock. :(
OldSpool87 06-07-2014 05:49 AM
Tippy, if you saw the price of the plug your mangled clock solution might look more attractive.
billjam 06-07-2014 06:37 AM
I used a PVC pipe cap. It was a while ago, but it must have been a 75mm pipe cap with an OD of 80mm because it fitted in just right. Drilled and filed a hole for the gauge and glued some vinyl on.
$0.50 :)
http://forums.pelicanparts.com/uploa...1402148117.jpg
Rleog 06-07-2014 08:24 AM
$0.50 :)
I like your style, Bill. Mine is for a 911 style (Getty) dash in a 914 and this fits the 'bill' nicely.
Thanks all.
dicklague 06-07-2014 10:46 AM
Here is my setup with a Daytona-Sensors WEGO IV [sold by our hosts PP] The plug is also sold by our hosts.
You can download data from the mini USB port on the front and the unit is completely self-contained with no additional boxes.....just a wire to the wideband sensor.
The upper digital readout is a combination digital clock, voltmeter, temperature gauge. You can toggle through with the right spring loaded toggle switch, or you can set it for 5 seconds on each function.
This way you keep your clock, get AFR and voltage and temp.
http://forums.pelicanparts.com/uploa...1402163180.jpg
http://forums.pelicanparts.com/uploa...1402163207.jpg
The left toggle is for switching from oil cooler temp to outside air temp.
john930 06-07-2014 11:04 PM
I gutted an old gauge and used some PVC pipe to make a mount inside. [/LIST]http://forums.pelicanparts.com/uploa...1402207410.jpg
rsscotty 06-08-2014 12:37 AM
Here are pictures of the speedo & clock delete plug....
Welcome to Rothsport Racing - Chassis Products
dicklague 06-08-2014 06:32 AM
THAT IS WHAT I started with. Well made machined plastic
Rodsrsr 06-08-2014 07:51 AM
Why are all the gauges so small? Doesn't anyone just make a larger air/fuel gauge? :mad:
dicklague 06-08-2014 01:36 PM
my setup is very easy to read. Large digital numbers. Good night of day
TimT 06-08-2014 05:45 PM
The extreme
http://www.wbo2.com/bd1/im/bd1_lhs.jpg
TechEdge
There other displays are bit larger than a 2-1/16 round gauge
http://www.wbo2.com/bd1/im/cmp_disp.jpg
