A/F meter in dash clock position
Have any of you installed a 2 1/16" diameter A/F meter in the clock space? If so, what did you use to adapt the smaller gauge to the dash space?
Bob G ‘87 Carrera Targa ‘74 914/4, much modified |
Chain fence eating turbo
The clock lens. I whittled a hole in a busted clock, painted lens black, and mounted WBO2 to it.
Uncertifiable!!!
🇨🇦 The True North Strong and Free 🇨🇦 Living well is life's best revenge- George Herbert (1593-1633) 2006 C2S, 2024 WRX GT, 911 hot rods on Pelican…. Evolution of a Carrera RST, and Sweet Transplant |
Our host sells a plastic plug for the gauge (delete plug). I got one and hole sawed approximate diameter. Looks pretty good.
I have used the plastic clock plug that Pelican sells. It is a very nice machined piece.
I just finished the install using the Daytona-Sensors WEGO IV unit. This one is all self contained and you can download data from the front panel USB connector. I have also built in a digital readout above it that is a clock, volt meter, and temperature gauge. I will post photos tomorrow.
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
If I'd known Pelican had the plug, I wouldn't have mutilated a clock.
Tippy, if you saw the price of the plug your mangled clock solution might look more attractive.
Certified User
I used a PVC pipe cap. It was a while ago, but it must have been a 75mm pipe cap with an OD of 80mm because it fitted in just right. Drilled and filed a hole for the gauge and glued some vinyl on.
$0.50 ![]()
Bill 1988 Carrera - 3.6 engine with ITBs, COPs, MS3X 2024 Macan S Day job ... www.jesfab.com.au Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911, '21 Macan S |
Thanks all.
Here is my setup with a Daytona-Sensors WEGO IV [sold by our hosts PP] The plug is also sold by our hosts.
You can download data from the mini USB port on the front and the unit is completely self-contained with no additional boxes.....just a wire to the wideband sensor. The upper digital readout is a combination digital clock, voltmeter, temperature gauge. You can toggle through with the right spring loaded toggle switch, or you can set it for 5 seconds on each function. This way you keep your clock, get AFR and voltage and temp. ![]() ![]() The left toggle is for switching from oil cooler temp to outside air temp.
I gutted an old gauge and used some PVC pipe to make a mount inside. [/LIST]
Here are pictures of the speedo & clock delete plug....
Welcome to Rothsport Racing - Chassis Products |
Grappler
Why are all the gauges so small? Doesn't anyone just make a larger air/fuel gauge?
Grappler Know Gi / No Gi 1976 RSR Backdate (Turbo 3.2) |
my setup is very easy to read. Large digital numbers. Good night of day
Navin Johnson
![]() TechEdge There other displays are bit larger than a 2-1/16 round gauge
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
