Paul Shepherd's Avatar
3.2 Engine Drop
Going to drop my engine to replace the clutch and I have a couple of questions
1 - should I drop just the engine or engine/trans
2 - where should I support the weight on the jack, I will fabricate an adapter
3 - is it worth installing a lightweight flywheel
thanks Paul
1984 4.7 928 S2 owned 2015 to present
1986 3.2 911 Carrera Coupe owned 1996 to present
1974 2.7 911S Targa owned 1990 to 1996
1980 3.0 911 SC Coupe owned 1985 to 1987
Old 06-06-2014, 07:14 PM
Hi
Targa Me's Avatar
1. Most folks prefer to drop eng/trans. It's the easiest way.
2. I use an ATV jack for the engine with 2x4 pieces supporting the heat exchangers.
3. A lightweight flywheel will eliminate your engine brake. I would stick with the stock flywheel.
4. Replace the crankshaft seal and flywheel bearing.
5. Replace both shaft seals on the trans.
6. Drain the trans oil before you drop the eng/trans.
7. Replace the trans oil when the trans is on the ground, its easier to fill.
8. Kendall gear oil works best in my 915. Kendall 80W-90 GL-5 NS-MP Hypoid Gear Oil (1 Quart) PN KEN-HYP 7728. (Sold by our Host.) Also there is a Kendall oil if you have a LSD trans.
9. With the engine on the ground its a good time to tune-up. Adjust valves, replace all fuel hoses, that's a must.
10. Check for engine oil leaks and repair as required.
11. Search for Threads on this. I think there's one call, "While I'm There".
12. Good luck and have fun with it.
"A good sense of humor is the best thing to have in your toolbox when working on these cars."
Quote by Charles Freeborn, Pelican.
Old 06-07-2014, 05:38 AM
